Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 02-27-2012, 11:30 AM   #16
Tom Struble's Avatar
Front windows leaking
you could probably just cut the caulk at the window/head and pull it out to take a peek
be careful up there
Tom Struble is offline   Reply With Quote
Old 02-29-2012, 12:51 PM   #17
From the looks of your pics it appears that the windows were not flashed properly. Our company has been across this country repairing issues such as this and the culprit has been, far and away, improper flashing/installation of weather barrier. Pray that its just a flashing issue that can be repaired with minimal rock removal.
Alfalfamike is offline   Reply With Quote
Old 02-29-2012, 02:34 PM   #18
Well, it's raining today (a light rain, but enough wind where it hits the front of the house) and the window is again leaking. Unfortunately, this level of masonry and reflashing (if that's all it is) is a bit beyond my scope of DIY (no metal brake or masonry tools).
I'm going to take the plunge and call someone to see about repairing it. I'll keep you posted as to the exact cause once someone comes to open it up.
dengle is offline   Reply With Quote
The Following User Says Thank You to dengle For This Useful Post:
Tom Struble (02-29-2012)
Old 02-29-2012, 04:20 PM   #19
Windows & Remodeling
HomeSealed's Avatar
That probably a good choice.
HomeSealed is offline   Reply With Quote
Old 02-29-2012, 04:55 PM   #20
Exterior Construction
Windows on Wash's Avatar
+1
Post back up after you get the contractor out there and what his discovery is.
Old 03-01-2012, 12:14 AM   #21
Moderator
Check out this window detail (with sealant/flashing for the different expansion/contraction rate materials) at the jambs compared to yours, and the head/sill: http://www.reisterstownlumber.com/im...edures_new.pdf
Gary
Clothes taking longer to dry?
Old 03-03-2012, 01:20 PM   #22
Well, I had a general Contractor come out to take a look and he agrees that the windows were not installed correctly but could not tell if that was the cause of the leak. He did say he didn't feel comfortable with the job due to the Masonry involved and the unknown source of the leak. he mentioned that such an issue might be covered under homeowners insurance. is that possible? I haven't dug out my policy yet to see what's covered.
As an added bonus I found more issues with this front window. what do water and wood typically bring? yep some kind of bug infestation.
With obvious signs of water on the carpet tack strip:
Better picture of the bugs. winged ants, termites or carpenter ants? I saw no live ones which leads me to believe they were previously treated by the prior owner.
The joys of home ownership!
Edit: multiple word issues due to using phone with poor Auto correct...
Old 03-04-2012, 01:21 PM   #23
I had a mystery leak into a 1st floor bay window only during wind driven rains. After thinking it was a flashing issue above the bay window I had the counter flashing replaced. Leaks continued only during wind driven rains. My culprits were the window sills of two windows on 2nd floor above the bay.
-I ended up having all seven rowlock sills replaced with limestone sills on front of house.
At first my worst thought was that the brick veneer was screwed up somehow. I had a local company that does brick restoration come in and he showed be a Rhilem Tube test to demonstrate how the brick can absorb water.
Here is an excellent video demonstrating a Rhilem Tube:
http://www.youtube.com/watch?v=SFurv7A42tM
After learning that brick veneer--mortar joints and bricks--can absorb water, I had a water repellent made by Prosoco called Siloxane WB concentrate applied by to entire front brick veneer of the house.
http://www.prosoco.com/Products/8258...6-57731831a3c9
I know in your situation you do not have the window sills as I did but do not rule out the possibility of the stone veneer leaching water to the backside of the veneer. With a hose test hopefully you can narrow down your culprit.
hammerlane is offline   Reply With Quote
Old 03-04-2012, 01:38 PM   #24
I would plan on, and you might be just as advised, to gut the interior walls around the windows and get a real up close and personal look at the source of the leaks.
I will likely be required by any insurance adjuster as well.
Old 03-04-2012, 01:43 PM   #25
Any masonry wall is going to leak water and not be water tight...hence the reasoning behind a vented wall assembly.
The issue in this case is likely going to be a result of the tie in of the window to the home and the lack of water management at the window.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (03-04-2012)
Old 03-04-2012, 01:49 PM   #26
I may have to do that to fix the water damaged subfloor under the window anyway. its pretty black... as to the hose test, when the weather is warmer, I'll be doing that.
In regards to using a sealer for the mortar, shouldn't the installation have taken the water permeability into account? I could have sworn I read that sealing stone facing may not be the breast thing for it...?
Old 03-04-2012, 01:51 PM   #27
You are correct. And I did not reference using a sealer.
I referenced using a water repellent.
Big difference.
The Prosoco product will not. impair the natural breathing characteristics of treated surfaces.
As a note to others reading this. Above I referenced the Siloxane WB concentrate. This needs to be mixed on site with specific quantities of water. The company that applied it for me were the experts so thats what they used. They did tell me if I were to do it myself they recommended the Siloxane PD which is pre-diluted. Its ready to be applied right out of the container.
http://www.prosoco.com/Products/d113...e-b0006e080476
Old 03-04-2012, 02:04 PM   #28
i know your situation was different,but usually i find the problem is not as ''exotic'' as absorption usually it's a more fundamental screwup in basic lapping or shingling
The Following User Says Thank You to Tom Struble For This Useful Post:
kwikfishron (03-04-2012)
Old 03-04-2012, 02:07 PM   #29
+1
That is about 95% of the issues out there but I have seen several of Hammerlane's issues with brick sills above a bay window like that.
Thanks for that post and video as well. Good content there.
Old 03-04-2012, 02:38 PM   #30
i agree, mind the gap
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 11:46 PM
Windows? Erickp40 Windows and Doors 5 11-17-2011 11:53 AM
Are My Windows Leaking Water? JRMN Windows and Doors 6 09-12-2011 07:06 AM
Red bricked arch over front doors (leaking)! doityourselfno Building & Construction 7 06-04-2010 05:26 PM
red bricked arch over front doors (leaking) doityourselfno General Discussion 1 05-30-2010 09:56 PM
