Front Door Threshold Adjusted, Now Leaking - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 10-17-2012, 10:18 AM   #16
Dan
Rewards Points: 35
Originally Posted by joecaption View Post
I saw that, but ended up w/ the one that attaches to the bottom...if this doesn't work good or doesn't last, i will probably try that next. With the new weatherstripping and the new sweep and the caulking, the door closes pretty tight, i don't see any light coming through...so hopefully it passes the hose test and I will be good...for a while anyway.
dankoos is offline   Reply With Quote
Old 10-17-2012, 10:29 AM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
Did you replace the weather strip on the underside of the door? Even new that type of strip is likely to leak with a heavy wind. A storm door or water diverter on the bottom of your door would be a help.
Joe beat me to it, that is the diverter I was talking about.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-17-2012, 10:33 AM   #18
Dan
Rewards Points: 35
I did..that is what I was talking about w/ the other gentleman. It does get beat up pretty fast, and YES, my immediate plan calls for a storm door which I believe will help a LOT. Anyone ever try the Andersen 2500 series storm door? Its between that from HD or a Larson from Lowes.
Water leaking under front door cm8567 Windows and Doors 6 09-16-2011 10:26 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Tub squeaks when front skirt is added snakefan Remodeling 3 07-21-2011 08:43 PM
Front landing leaking into basement when it rains cwyse Building & Construction 7 02-27-2010 08:36 AM
Air leaking around front door sadears Building & Construction 13 12-22-2009 06:52 PM
