Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-15-2012, 09:25 AM   #1
Dan
Front door threshold adjusted, now leaking
I have a steel front door with an adjustable threshold at the bottom. To be honest, I never knew the threshold was adjustable. Every couple years, since the front of the house faces the oncoming weather (West), water has been rotting out the door jam. I fix spots and water proof them, so the water finds new old spots. In any event, as part of the fix this time, I adjusted the threshold from all the way to the ground up a little so the door brushes it a bit more. I thought that would assist keeping out drafts and water. So last night, a driving rain had water seeping in worse than before! It was coming in on the hinge side and more in the middle, both places I never had an issue before. When you raise the threshold like that, does it need to be caulked underneath?? I just replaced some subfloor that was rotted near this spot and now have new tile there as well, want to keep it from rotting again.
Finally, how much will a storm door help w/ the water?? Thanks!!!
dankoos is offline   Reply With Quote
Old 10-15-2012, 09:42 AM   #2
Exterior Construction
Windows on Wash's Avatar
Adjustment of the threshold does not require recaulking. It should have space to drain engineered into it.
A storm door should provide you with some additional coverage.
Old 10-15-2012, 10:01 AM   #3
Dan
Thanks, just seems weird that water started coming from those places after that adjustment. Is it possible the wind just blew it past that "drain"? I have had all kinds of issues w/ keeping out the weather on this door. Hoping the storm door will keep it all in check. Maybe I will take some pics to see if anyone thinks something else is out of whack.
Old 10-15-2012, 10:09 AM   #4
Is there a stoop, deck, porch set even with the threshold on the outside of that door? If so there's 99% of your problum.
Was there a sill pan installed under the door?
How was it flashed under the door?
Is there a seal installed at the bottom of the door it's self?
Old 10-15-2012, 10:12 AM   #5
Dan
I have brick outside the door, so the door sits on bricks which are a step up from the small, concrete front porch. I think the answer to your next two questions is no...I didn't see any of those things when we had the floor up. What seal at the bottom are you speaking of? I will really have to take a few pics.
Old 10-15-2012, 10:31 AM   #6
http://inspectapedia.com/BestPractic..._Exterior3.htm
Aslo Google "sill Jamb" for some pictures of a one piece vinyl one that works even better.
Without the flashing you can count on the rot happening again.
Old 10-15-2012, 10:36 AM   #7
Dan
Great diagram, thanks! I suppose the whole door/jam has to come out to install something like that? Also, in my application w/ brick instead of a deck outside, where would the flashing stop, just past he aluminum threshold?
Old 10-15-2012, 10:40 AM   #8
The whole door would have to come out to do it right.
Once it's out is there a space between the brick and the subflooring where you could slide the flashing in?
Old 10-15-2012, 10:47 AM   #9
Prior to removing the door, you can seal the brick sill with Siloxane. That will help with the capillary movement.
Old 10-15-2012, 10:48 AM   #10
STAFF
BigJim's Avatar
I would recommend the flashing or ceil pan dump water on the outside of the brick instead of the space between the brick and the band, the water could rot your band if the water dumps into the hollow space.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 10-15-2012, 11:24 AM   #11
Dan
So what can I do as a temporary solution? Can I go ahead an caulk under the adjustable threshold? I already have calk at the front of the aluminum threshold, where it meets the brick
Old 10-15-2012, 12:33 PM   #12
STAFF
BigJim's Avatar
Until you can install the ceil pan the only suggestion I have is caulk everywhere you can that could let water in but chances are until you install a pan it will continue to leak. If water is coming through between the door and jamb, you might want to replace your weather stripping. If water is coming in over the threshold strip and under the door, you may install a water diverter on the lower part of your door just above the threshold. Another thing that may help is a water diverter on your roof overhang above the door.
Jim
Old 10-17-2012, 10:54 AM   #13
Dan
i bought a new weather strip for the bottom of the door, that is part of my problem. I also caulked the corners and under the threshold (the adjustable threshhold). Attached are some pics of the door.
Front door threshold adjusted, now leaking-door-1.jpg   Front door threshold adjusted, now leaking-door-2.jpg
Old 10-17-2012, 10:54 AM   #14
Dan
FYI, this is BEFORE the new weather strip and caulking.
Wanted to let the caulk set overnight, going to test w/ hose today
Old 10-17-2012, 11:16 AM   #15
http://www.bing.com/images/search?q=...+with+drip+cap
This is what I like to use.
Water leaking under front door cm8567 Windows and Doors 6 09-16-2011 11:26 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Tub squeaks when front skirt is added snakefan Remodeling 3 07-21-2011 09:43 PM
Front landing leaking into basement when it rains cwyse Building & Construction 7 02-27-2010 09:36 AM
Air leaking around front door sadears Building & Construction 13 12-22-2009 07:52 PM
