Front Door Sealing - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 02:18 PM   #1
Front Door Sealing
The rubber seal around the entire door has either shrunk or just worn over the years. You can see light shining thru between the wall and the door, meaning, we're losing lots of AC/Heat depending upon the time of year. What's the best way to repair?
Tom Zehnder is offline   Reply With Quote
Old 08-23-2011, 03:40 PM   #2
AGWhitehouse's Avatar
replace or re-install the weatherstripping
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-24-2011, 06:35 AM   #3
If the gaps disappears when you push the door shut, make sure the door lock latch is latching the door tightly. But weatherstrips do wear out and/or become compressed.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Tub squeaks when front skirt is added snakefan Remodeling 3 07-21-2011 08:43 PM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
design tall shower front to vent okiegal Plumbing 1 01-06-2011 03:25 PM
