Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-07-2013, 09:50 PM   #1
Front door Replacement
I am interested in replacing my front door with a new steel pre-hung door. The videos I have seen online make the job look pretty straight foward. Any tips or tricks to help me with the project. I can buy the door locally for about $150.00, I was going to just have it installed but I am being quoted about $400.00 in labor plus the door. So I think this would be a good weekend project.
streetneons is offline   Reply With Quote
Old 01-07-2013, 10:53 PM   #2
the best tip i can offer you = post pics, inside and outside.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 01-07-2013, 10:57 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Straightforward, not always. Depending on the amount of prep work, it can take anywhere from 2 hours if you are good at it, to a full 10 to 12 hour day doing the job, if it is a total disaster with the framing, or trim work. Let my wife help me hang our back door, and ended up two days later on my day off for Columbus day, she was at work, my son & I took it back down & redid the door, to get it square and properly hung. Luckily I did not lay down any caulk along the bottom Pressure Treated plate that we had to install, when we pulled the old door.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
The Following User Says Thank You to gregzoll For This Useful Post:
Windows on Wash (01-08-2013)
Old 01-08-2013, 09:20 AM   #4
Windows & Remodeling
HomeSealed's Avatar
1) Doors are trickier than meets the eye. Plan a full day if not two if you are a novice.
2) Proper measurement is crucial. Many original doors are shorter in height than the original which can pose some major issues once it is torn out, especially if it is set on a concrete stoop.
3) A $150 is going to be even HARDER to install than a good door. Poor manufacturing tolerances and assembly typically make it far more difficult to get a finished product that seals well AND operates smoothly. We used to install doors that our clients purchased from box stores, but no longer do for exactly that reason.
I suppose if it is your first shot, it's probably better to take a chance on a $150 door than an $800 door.
Most important first step: get the hinge side and threshold plumb and level, and adjust the rest from there. Godspeed.
HomeSealed is offline   Reply With Quote
Old 01-08-2013, 10:00 AM   #5
All that and make 100% sure the bottom of the door is flashed correctly and outside of the sill gets fully supported.
I'll be when you pull the old door out there will be no flashing under it.
It's very common to have some rot under the door because of this.
The first things to rot out on a cheap door like that will be the bottoms of the jambs and the lower part of the brick moulding.
A better door would have what's call end rot at the bottoms of the jambs. It's just composit or vinyl.
First thing I do is get rid of the wooden brick moulding and replace it with vinyl brick mouding.
A better door would also have an adjustable sill, this way if the floor is off you can adjust it, also with an adjustable sill the seal is on the door not built into the threshold so there's less chance of it getting damaged.
Old 01-08-2013, 05:08 PM   #6
remodeling pro
My first tip would be to stay away from the steel, get fiberglass. Look around and you will quickly find that any steel door that has any type of weather exposure is rotted at the bottom edge after 4 or 5 years.
As others have cautioned, this task is within the real of a reasonably handy DIYer, but there is the potential for many problems.
troubleseeker is offline   Reply With Quote
Old 01-08-2013, 05:17 PM   #7
Ever steel door I've seen that was rusted is because the doors are shipped primed and have a sticker right on them to paint with acrilic latex paint within 48 hours of installation, some just never got painted.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
HomeSealed (01-08-2013), Windasman (02-02-2013)
Old 01-08-2013, 07:35 PM   #8
gregzoll's Avatar
Depends on the manufacturer. The door we got from Menard's was powder coated, and no painting needed. Still have to paint the frame this Spring, since it was October when we put it up, and has not warmed up enough for a decent day to paint and let dry, with the door open.
Old 01-08-2013, 11:16 PM   #9
HomeSealed's Avatar
I prefer fiberglass as well, but a quality steel door that is properly finished will last. Some of the higher end units actually put a pretty long warranty (from 7 years up to lifetime) on their steel doors when ordered with a factory finish.
The Following User Says Thank You to HomeSealed For This Useful Post:
Old 01-08-2013, 11:46 PM   #10
funfool's Avatar
Something I did not see, poster says can get a steel door for $150
Is this just a blank?
Or is going to install a prehung door?
streetneons, is nothing wrong with going either way ... Just a whole set of different instructions for which way you go.
A blank would mean leaving your old door jambs in place, and simply replace the door.
A pre hung would require removing the trim and cutting out the old jambs ... and decide what is required to install new.
If it was easy, we would not call it work!
funfool is online now   Reply With Quote
Old 01-09-2013, 12:07 AM   #11
Exterior Construction
Windows on Wash's Avatar
+1
After having spent about 4 hours trying to make a blank fit right, I will never do it again.
Door installs can be a pandora's box if not careful and take a good, long while.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 01-09-2013, 07:12 AM   #12
HomeSealed's Avatar
Fun fool and wow, reread the very first sentence of the very first post.
Old 01-16-2013, 04:52 PM   #13
Where do you get that quote? I plan to replace my entry door too, but Lowes & Home Depot charge > $1000 for labor.
hvo2004 is offline   Reply With Quote
Old 01-16-2013, 05:02 PM   #14
gregzoll's Avatar
Probably local handyman. Never have Lowe's or Home Depot do any type of work in your home, with the exception of delivering building materials & appliances.
Old 01-16-2013, 05:44 PM   #15
$1000.00 Give me the address I'll do it for $999.00.
I was in Lowes the other day and there was about an 80 year old lady wanting all new replacement windows, the salesman told her there was a charge to do an estimate, and suggested if she want to save the cost to go home and measure them her self.
Not sure about you but I sure would not some 80 year old lady measuring anything.
Squaring a walkway off the front steps? Boiler98 Building & Construction 3 07-14-2012 09:31 PM
Replacing a concrete front door approach with a boardwalk? bigdaddydavy Building & Construction 10 05-31-2012 10:08 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 07:08 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
