Front Door Opened By Its Self And Is Now Out Of Alignment From The Frigid Cold - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 12:00 PM   #1
Front door opened by its self and is now out of alignment from the frigid cold
Couple days ago it was -23 and we were sitting on the couch when the door just blew open front te wind and freezing cold. Now the door doesn't match with the strike plate. The door appears to be sitting above the strike plate now. Help? Lol thank you
rhanson85 is offline   Reply With Quote
Old 01-30-2014, 12:12 PM   #2
Rewards Points: 14,312
To check, close the door until the latch just touches the strike plate and mark it with a pencil at the top and bottom of the latch.
You may get lucky and it's just some hinge screws loose.
If that's not it then removing one of the screws and replacing it with another one at least 2-1/2" may pull the door back in place.
If it's to low then it's the top hinge, to high it's the bottom one.
Once it latches check the exposure from to bottom on the latch side. There should be about a 1/8" gap.
Any larger and the door may need to be reshimed.
Old 01-30-2014, 01:07 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Is the door or jamb damaged or split at the hinge locations?
Old 01-30-2014, 03:02 PM   #4
It's very likely it's your foundation moving, causing the door to get out of adjustment.
Frost heaving.
Adding your location to your profile often gets less guess and more answers.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
concretemasonry (01-30-2014), Windows on Wash (01-30-2014)
Old 01-30-2014, 05:03 PM   #5
I wonder if when the door flew open if it was whipping hard enough if it didn't exacerbate the door condition.
I agree though...at -23...stuff if happening on the ground level.
Old 01-31-2014, 08:14 AM   #6
Why would they replace the strike plate?
If it was working before it should work now.
Old 01-31-2014, 08:47 AM   #7
Striker....?
