Front Door Hard Plastic Piece Cracked - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 10:43 PM   #1
Front door hard plastic piece cracked
I have an aluminum sill and steel door that is in good shape, but the hard plastic piece over the aluminum sill that the door sweep connects with is cracked. I have never noticed any moisture issues in the house. Is it possible to replace the piece of plastic - I notice there are two screws it look like holding it down a few inches from either side of door frame.
Seems like a shame to have to either replace the whole aluminum threshold or entire door for a small strip of hard plastic. The crack is currently covered with some white vinyl tape.
Gingermanrx is offline   Reply With Quote
Old 05-29-2013, 06:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,706
In all likelihood, you cannot just replace that threshold. They are typically one unit and affixed to the jambs of the door via nails and screws from the underside.
You may be able to purchase a replacement plastic strip as it probably just clips over the extruded aluminum piece.
Do you know the manufacturer of the door?
Old 05-29-2013, 07:30 AM   #3
Nope, I am not sure who the manufacturer of the door is. I know the house has peter kohler windows so I am not sure if they would have used the same brand entrance system or not.
Should I be concerned about water coming in, or is this mostly just a cosmetic thing?
Old 05-29-2013, 09:12 AM   #4
Its more cosmetic and for air tightness.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Finish piece in front of brick fireplace? moneymgmt Flooring 3 05-11-2010 08:27 PM
Front door flashing AVIDA Remodeling 1 02-16-2010 09:40 PM
wood piece underneath front door sill llckll Flooring 1 08-25-2009 06:12 AM
Caulk underneath sink drain/plate? doogie88 Plumbing 14 04-16-2009 07:18 AM
