French Doors - Bottom Seal Replacement - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 08:06 AM   #1
Rewards Points: 398
The bottom seal on my French doors is very broken apart to the point you can place your hand on the floor and actively feel air coming through - sometimes bugs make their way in too.
I think they were originally installed poorly with the house which is why it broke apart over time.
The left door holds the air seal but is never used. When I do open it, it's hard to do and you can feel the bottom seal rubbing across the bottom.
I tried replacing the seal on the right door with one from Home Depot and although it fit correctly, made the door almost I possible to open and close from the bottom dragging.
Is there a way to lower the bottom some so the seal moves nicely with the door? How can I correct this?
I can't find any brand markings on the door to contact the manufacturer with. I attached a picture of the type of seal that worked with this door. (Type that pushes up)
French doors - bottom seal replacement-image-721239466.jpg   French doors - bottom seal replacement-image-1854219286.jpg   French doors - bottom seal replacement-image-3459053826.jpg   French doors - bottom seal replacement-image-3279879691.jpg   French doors - bottom seal replacement-image-1503868548.jpg
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 12-30-2013, 08:52 AM   #2
Rewards Points: 13,750
That's an adjustable sill.
Just back the screws out slightly and tap down lightly with a hammer and a block of wood or a rubber mallet.
Going to need a big Phillips screw driver, to small and you can strip out the head.
Old 12-30-2013, 08:59 AM   #3
Rewards Points: 398
Thanks - I will give that a try. I was doing the opposite and trying to tighten the screws thinking it would lower down some.
install used wood french doors subvet Windows and Doors 16 02-17-2012 06:53 PM
reinstalling floor vent in front of French doors Cynick Building & Construction 1 11-15-2011 01:34 PM
Need Advice: Resizing off the shelf french doors Dgreaney Windows and Doors 6 06-09-2011 10:34 PM
Pair of French Doors/ one is warped nyc1dxo Carpentry 8 04-28-2008 07:10 AM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
