Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-29-2013, 07:48 AM   #1
French door install slightly off...
Everything is perfect with this door install except the active door needs to be closed a little hard for it to latch. Also the knob pops a little when released whiling opening. What needs to be adjusted? Move the entire active door jam in or out? So close!
Freakaloin is offline   Reply With Quote
Old 01-29-2013, 09:35 AM   #2
STAFF
BigJim's Avatar
As long as the door isn't dragging it should be good, usually it is pushing the seal that makes it hard, if it is, that is a good thing because you know it is keeping the weather out and your warm air in.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-29-2013, 09:46 AM   #3
You did install a sill pan or at least flash under the threshold, up the jambs, and behind the siding, right?
One of the most common mistakes builders and DIY's alike make is skiping this one simple step and can cause 1000's of dollars in damage to the home.
And no some silicone under it will not keep the water out?
Is the outside of that threshold where it over hangs the sheathing fully supported? If not it will twist it and cause the seal to break on the outside edges.
Old 01-29-2013, 10:07 AM   #4
Super Moderator
Put your level on the left and right jams and see it they match--exactly----if not---that's your problem---
some french doors have adjustable hinges for fine tuning---you just might get lucky there---
oh'mike is online now   Reply With Quote
Old 01-29-2013, 10:14 AM   #5
Also just look at the exposures at the top of the door and along the area where the two doors meet. They should all be even.
You did use the 3" long supplyed screws in the hindges right?
If the doors off sometimes simply playing with those screws can fine tune the door.
HomeSealed (01-29-2013)
Old 01-29-2013, 10:31 AM   #6
I installed a sill pan. I haven't flashed around door yet but the siding isn't up yet. Everything is plumb and square and straight. The bottom hinge on the inactive door came from the factory a little out of the inlay but I doubt that's it. I'll adjust the hinges first and see if that helps. There's a second set of French doors next to this one btw. It closes easier. It's a minor issue but it bugs me. Seems these French doors installed without a need for shimming...weird. I had to shim the crap out of the single door I installed on other side of room...
The Following User Says Thank You to Freakaloin For This Useful Post:
BigJim (01-29-2013)
Old 01-29-2013, 10:39 AM   #7
Also...do I need to put a drip cap on this or something?
Old 01-29-2013, 10:44 AM   #8
Swing around and take another picture facing the door.
Is there a nailing flange on the door?
Who cut the sheathing back like that?
Old 01-29-2013, 10:51 AM   #9
STAFF
BigJim's Avatar
With that much overhang you shouldn't have to have a drip cap or flashing but if it were mine I would install one anyway, just to be doubly sure.
Jim
Old 01-29-2013, 10:58 AM   #10
I know. I forgot to leave a little excess with the felt. I also had a larger than expected gap above door and added a 1x4(after I sheathed). Gap is still rather large
Old 01-29-2013, 11:20 AM   #11
Is the jamb on the door at least even with the face of the sheathing?
Make sure to at least use vinyl brick mould on the outside to prevent any rot.
I do see one huge issue, that patio never should have been pored that high.
Now there's sure to be water getting in under that threshold and would not be surprized if there was not already some wall, bottom plate damage, or rim joist damage.
Code calls for sheathing and thresholds to be no closer then 4" to grade.
If there's room enough I'd try and slide in some coil stock or flashing between the slab and the wall.
That door needed to flashed something like this or there's going to be some problums later on.
http://www.bing.com/images/search?q=...lectedIndex=91
Old 01-29-2013, 11:28 AM   #12
Super Moderator
Just so you don't feel to bad---French doors---really any double door---are a big challenge even for a very experienced installer-----and those doors don't look like ones with the fancy adjustable hinges that allow for some play in the install---
Old 01-29-2013, 11:37 AM   #13
This is an old half converted car port. Water was an issue and I had to replace the base plates to the wall because the were rotten. I added a gutter and replaced flat roof. If needed I will smash that concrete out!
Old 01-29-2013, 11:47 AM   #14
Super Moderator
Cutting in a channel drain in front of the doors might actually be something to do------
Old 01-29-2013, 04:56 PM   #15
Windows & Remodeling
HomeSealed's Avatar
Simple check (as Joe alluded to) is to check the reveals and make sure that the slabs sit flush with each other and the jambs. That will give you a great idea of whether or not everything is plumb and level. If it is, you can putz around with little things here and there to make it operate more smoothly, but you'll have your work cut out for you because it could very well be a "loose" factory assembly, or some component slightly out of spec. You didn't mention what type of door it was, but this is often the case with cheaper doors. Even high-grade french door units can be VERY finicky to install.
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
oh'mike (01-30-2013)
future paver patio over old french drain? D270 Landscaping & Lawn Care 0 08-21-2011 11:28 AM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 11:55 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 10:37 AM
French Drain Solution? Any Help Would Be Great! gregt848 General Discussion 2 08-01-2008 10:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
