French Door Bolts - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 09:51 PM   #1
Rewards Points: 1,648
French door bolts
I have a set of french doors and a part is broken. I am not sure what it's called.
Here is a picture of the french door.
The left side opens and closes. The right half usually stay closed. There are two rods - one on top, one at the bottom, that goes into the door frame to hold the right side in place, what do you call that?
Anyways, the top metal rod, seems to be broken. I am not able to push the rod up into the frame to secure the door. So when I push the left door open, the top of the right door get pushed out an inch or so while the bottom stay put.
The problem at the bottom is the opposite. The rod is driven into the frame and I can't seem to get it to come up. It's stuck. I should be able to just push up on the plastic tab and it should come up, right?
Brand is JELD WEN.
miamicuse is offline   Reply With Quote
Old 02-04-2014, 10:34 PM   #2
Rewards Points: 14,294
Door looks like it's out of plumb. See where it's been dragging on the top of the door?
Old 02-05-2014, 04:07 AM   #3
DIY staff
Rewards Points: 7,174
Call Jen Weld ---you have a door with a fixed astrogil--(spelling)
Be patient---we have some window and door specialists here--one will spot this post.--Mike---
Old 02-05-2014, 06:14 PM   #4
DIY staff
Bump-----
French Drain Merge into Solid Drain catahoula22 Landscaping & Lawn Care 0 07-19-2013 01:38 AM
future paver patio over old french drain? D270 Landscaping & Lawn Care 0 08-21-2011 10:28 AM
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 10:55 AM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
