Framing In Windows And Wrapping Them??? - Windows and Doors - DIY Chatroom Home Improvement Forum
Closed Thread
Old 03-10-2014, 03:21 PM   #1
Rewards Points: 300
Framing in windows and wrapping them???
Im currently doing a remodel and Im replacing the windows with new construction all vinyl Jeld Wen ones. I have the lower level windows done already and they are boxed in with cedar. I will be doing the upper level windows this spring and I like the idea of framing them in. An uncle of mine mentioned about wrapping them in aluminum... Should I still use cedar to frame around them or can I use something else? if its something else, should I replace the cedar that I have with the others???? Im going to be residing also with vinyl... Im an avid learner and willing to listen to all ideas.. thanks in advance...
timothy300858 is offline
Old 03-10-2014, 06:30 PM   #2
Rewards Points: 144
You can wrap any kind of wood with aluminum.Cedar is an added expense if you are going to wrap them .You could use SPF.I'm assuming you are talking about something like 1 x 4's?
If you wish to wrap them you will need a siding brake.These are not difficult to use but there is a learning curve and a certain way it needs to be done for them to be water tight.
Check out some videos on youtube for a better idea of what your getting into.
mako1 is offline
Old 03-10-2014, 06:38 PM   #3
Rewards Points: 13,228
If your going with vinyl you should have bought windows with built in J moulding.
Another way would be to have used wider J moulding.
Were at a lost because you have not posted any pictures of the house.
joecaption is offline
Old 03-10-2014, 07:01 PM   #4
Rewards Points: 300
Well if I knew how to add pictures here I would lol.... I just took a couple so if I do, I will post them... And Im in Nw Indiana btw...
Old 03-11-2014, 04:31 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Good advice from Mako. Not to flame Joe, but I'm not a fan of the look of built in J. It is cheaper and looks cheaper IMO. You could look at some PVC and composite trim products however that would not require wrapping.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (03-11-2014)
Closed Thread
Replace original windows myself? SuperJETT Windows and Doors 13 04-27-2015 03:19 PM
Making the drip caps over windows look better tgm1024 Building & Construction 14 12-07-2010 04:17 PM
Wrapping wood trim for replacement windows Sparky 55 Building & Construction 21 04-21-2010 05:09 AM
Muratic acid on aluminum clad windows jarrodbowles General DIY Discussions 25 05-01-2009 05:42 PM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 07:10 PM
