-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Framing in windows and wrapping them??? (http://www.diychatroom.com/f104/framing-windows-wrapping-them-197584/)
timothy300858 03-10-2014 02:21 PM
Im currently doing a remodel and Im replacing the windows with new construction all vinyl Jeld Wen ones. I have the lower level windows done already and they are boxed in with cedar. I will be doing the upper level windows this spring and I like the idea of framing them in. An uncle of mine mentioned about wrapping them in aluminum... Should I still use cedar to frame around them or can I use something else? if its something else, should I replace the cedar that I have with the others???? Im going to be residing also with vinyl... Im an avid learner and willing to listen to all ideas.. thanks in advance...
mako1 03-10-2014 05:30 PM
You can wrap any kind of wood with aluminum.Cedar is an added expense if you are going to wrap them .You could use SPF.I'm assuming you are talking about something like 1 x 4's?
If you wish to wrap them you will need a siding brake.These are not difficult to use but there is a learning curve and a certain way it needs to be done for them to be water tight.
Check out some videos on youtube for a better idea of what your getting into.
joecaption 03-10-2014 05:38 PM
If your going with vinyl you should have bought windows with built in J moulding.
Another way would be to have used wider J moulding.
Were at a lost because you have not posted any pictures of the house.
timothy300858 03-10-2014 06:01 PM
Well if I knew how to add pictures here I would lol.... I just took a couple so if I do, I will post them... And Im in Nw Indiana btw...
HomeSealed 03-11-2014 03:31 PM
Good advice from Mako. Not to flame Joe, but I'm not a fan of the look of built in J. It is cheaper and looks cheaper IMO. You could look at some PVC and composite trim products however that would not require wrapping.
