Framing New Basement Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-29-2013, 11:55 AM   #1
Framing new basement window
I am installing a bigger basement window, cutting a larger opening in my basement foundation.
I am putting in jackstuds (2X10s) and a steel header.
My question: Do I need a separate frame on the sides, or can I get away with attaching the new window to the jackstuds? I can use separate wood at the top and bottom without an issue.
I ask because I am trying to limit the width of the window opening, so even saving an inch would be helpful.
Thanks in advance!
ReginaAndrew is offline   Reply With Quote
Old 09-29-2013, 08:20 PM   #2
DIY staff
Rewards Points: 7,174
I'm unsure of what you are doing---are you installing this into a concrete or block wall?
Old 09-30-2013, 12:43 AM   #3
It is going into a concrete basement wall - not a block wall -- the house is 45 yrs old. I am cutting a hole about 43 inches wide by about 30 inches deep, and removing a smaller window. I will use bolts to attach to the 2X10 jack studs to the concrete edges, and then just screw the window to the jack studs.
I cant imagine a need for a separate frame inside the jack studs ... just wanted to make sure I was not missing something.
Old 09-30-2013, 01:00 AM   #4
Rewards Points: 2,238
You may not really need bolts - you might be able to use "Tapcons".
If you're using a steel header (if it's installed correctly) all you need
is something to fasten the window to -
pressure-treated lumber?
Vinyl window?
Is this an escape/egress window?
rossfingal is offline   Reply With Quote
Old 09-30-2013, 01:05 AM   #5
Yes - I have a Remington nail gun. I may just nail it. The engineer report calls for bolts stuck into the cement several inches. Some guys here use Sikaflex 1A and nothing else to fasten it to the concrete
Yes, it is an egress window. Yes, it is vinyl and yes, I will use pressure treated 2X10s.
Old 09-30-2013, 01:08 AM   #6
If it's an escape/egress window -
better check for what your local code is for size and hieghth from the
floor is.
Old 09-30-2013, 01:10 AM   #7
Yes - the size and window placement surpasses city requirements.
Old 09-30-2013, 01:18 AM   #8
That's good!
However, remember - depending on the exact type of window -
single-hung, double-hung, slider etc...
The "actual" size of the escape/egress OPENING should be taken into
consideration!
Old 09-30-2013, 02:00 PM   #9
Registered User
Rewards Points: 5,204
IMO, use pt wood with Grace Vycor between the concrete/wood to stop capillary action. Add two beads of sealant (or sill sealer poly material) at that joint for air blockage. Tapcons or lag bolts as directed, don't cheap-out with nails only. Add caulking/sealant in the tapcon holes before install.
Gary
Old 09-30-2013, 03:58 PM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Are you putting this in the middle of the wall or something? ... Just asking because most basement windows start at the top of the foundation, so no steel header/jack studs would be necessary. If you had an engineer make the recommendations I'm sure that you are on the right track, just wondering.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-01-2013, 11:45 PM   #11
Sorry for the delay in my response.
There is about 12 inches of foundation above the window - there are three joists that rest on top of the foundation where the window is.
Now I am trying to find instructions on how to install a steel header - I suppose I just get it to fit nice and snug, and let it rest on the jack studs and give it a good coating of caulk.
Old 10-05-2013, 05:50 PM   #12
Typically, a steel header (called a lintel) is supported by the surrounding structure. In your case, a notch would be made on either side of your cut opening for the beam to sit on. Minimum 6" of bearing, typically 8" each end. Keep in mind this is now it is done in commercial construction, I am not privy as to how it differs in residential.
jbfab is offline   Reply With Quote
Old 10-05-2013, 08:07 PM   #13
I chatted with the engineer and received more clear instruction -- the steel header needs to sit on the two jack studs, which need to be 2X10s pressure-treated fir.
Basement remodel planning - Guidance needed for framing around oddities visim14 Remodeling 4 11-13-2012 12:27 PM
Finishing Basement - Framing with 2x2's mark2741 Building & Construction 13 12-25-2011 08:20 PM
HELP! Water Leaking Into Basement Window COPYCAT Building & Construction 5 03-23-2011 05:57 PM
box around window in basement BlueBSH Carpentry 2 10-08-2010 01:11 PM
Rain & mud splashing onto basement window gam7 Landscaping & Lawn Care 2 10-25-2009 02:49 PM
