Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-14-2012, 09:35 PM   #1
Framing door from scratch
I was told from builder that door to the garage from inside house is ready to install. That means frame was done inside drywall. So I went ahead to crack the drywall from the garage side, leave inside drywall as is.
And I realized that there is no frame. I noticed no header up there. There is just 16"apart stud.
Now I have outside drywall open and I gotta get this donn somehow.
I NEED HELP!!!!!
Can I knock down middle stud and build trim stud and header and so on? Kinda I think backward.
Than my rough open will be too narrow.
What should I do to get my door done?
kyungyun is offline   Reply With Quote
Old 09-14-2012, 09:43 PM   #2
Going to have to cut the sheetrock out far more then one stud bay.
It's easyer to cut it from floor to ceiling, much easer to patch a new piece in.
http://www.ezhangdoor.com/properly-f...-rough-opening
Old 09-15-2012, 12:22 AM   #3
To determine what/if you need a full-size header, you need to figure out if the wall is loadbearing or not. If not loadbearing, then a 2x4 on the flat is fine. If loadbearing, then you will need to frame a loadbearing header.
chrisBC is offline   Reply With Quote
Old 09-24-2012, 12:19 PM   #4
Job well done. Thanks for all guy reply me.
Framing door from scratch-image-3137669494.jpg   Framing door from scratch-image-4111786038.jpg
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
