-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Framing door from scratch (http://www.diychatroom.com/f104/framing-door-scratch-156839/)
kyungyun 09-14-2012 09:35 PM
I was told from builder that door to the garage from inside house is ready to install. That means frame was done inside drywall. So I went ahead to crack the drywall from the garage side, leave inside drywall as is.
And I realized that there is no frame. I noticed no header up there. There is just 16"apart stud.
Now I have outside drywall open and I gotta get this donn somehow.
I NEED HELP!!!!!
Can I knock down middle stud and build trim stud and header and so on? Kinda I think backward.
Than my rough open will be too narrow.
What should I do to get my door done?
joecaption 09-14-2012 09:43 PM
Going to have to cut the sheetrock out far more then one stud bay.
It's easyer to cut it from floor to ceiling, much easer to patch a new piece in.
http://www.ezhangdoor.com/properly-f...-rough-opening
chrisBC 09-15-2012 12:22 AM
To determine what/if you need a full-size header, you need to figure out if the wall is loadbearing or not. If not loadbearing, then a 2x4 on the flat is fine. If loadbearing, then you will need to frame a loadbearing header.
kyungyun 09-24-2012 12:19 PM
2 Attachment(s)
Job well done. Thanks for all guy reply me.
