Flushing Jamb Up With Wall For Casing - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-19-2014, 03:05 PM   #1
Rewards Points: 83
Flushing jamb up with wall for casing
I purchased pre-hung doors at standard jamb width. In one room, I am using 5/8" drywall, and the drywall extends from 1/8" to 1/2" past the edge of the jamb on some doors.
In general, I'm hanging them with the hinge side as flush to the wall as I can get (but the wall is uneven even on these sides up to 1/8") and leaving the other side as the deeper set one so I don't have to deal with extending the jamb on the side of the hinges or the latch.
This is my plan. Could you folks tell me if this is a bad approach:
For 1/8" or less, I'm going to see if caulking will be enough to bridge the gap to the casing.
For 3/16" or more, I bought an extra jamb kit, and my plan was to:
- Rip thin strips of jamb as needed from the extra jamb, a little more (1/16" or so) wider than the depth gap
- Tack them on the edge with brad nails and wood glue - should I offset, even if the strip is only 3/16" wide?
- Install the casing as usual
- Putty and paint.
Are there better/faster ways to flush up the jamb? Is installing the hinge side flush the best approach?
Thanks all!
danielrg is offline   Reply With Quote
Old 05-19-2014, 06:11 PM   #2
Rewards Points: 13,750
Why would you use 5/8 on a wall? Only place it's needed is on the garage side of an attached garage.
No need for store bought jamb extensions, scriped 1 X S's work just as well.
danielrg (05-20-2014)
Old 05-19-2014, 09:08 PM   #3
Rewards Points: 256
take a piece of trim and hold it on sides and top of door / windows, draw a line around it with a pencil then take a hammer and mash the rock within the line to flatten it down . i see this all the time sometimes like townhouses require 5/8 etc but the framers don't always know it , then the trimmers get mad at the drywallers for using 5/8ths but code required it .
i didn't see 1/2 inch but i would get some pine and make a custom jam or what i did was remove the stops then cut the jam down on a table saw , then add to the jam and put the seam under the door stop so you cant see it ..
oldrivers is offline   Reply With Quote
The Following User Says Thank You to oldrivers For This Useful Post:
Old 05-19-2014, 09:11 PM   #4
Rewards Points: 256
drywall is really crap right now "lightweight rock" id use 5/8ths on everything if it were me .
Old 05-20-2014, 10:09 PM   #5
Ideally you would get 4 7/8 jamb to fit. Sounds like you are past that. I always leave a little reveal no matter how small the extension I put on. Otherwise you always see a seam.
You can Definetely do as oldrivers said and smash the drywall in with a hammer. Just make sure that you cut the drywall with a knife first.
uncommon doors is offline   Reply With Quote
The Following User Says Thank You to uncommon doors For This Useful Post:
Old 05-20-2014, 10:41 PM   #6
Rewards Points: 83
I bought the 5/8" as part of a sound reducing scheme for a listening room. I was going to double it up with 1/2", but ended up bagging the whole plan - but already had a stack of 5/8" - that did help a little with sound.
Great point on the 1x lumber. Less expensive. Thanks.
Old 05-20-2014, 10:43 PM   #7
Rewards Points: 83
Yep - already put the doors in yesterday. The drywall plan will work well. I already did that on a small part with another door and it worked just fine. Thanks for the tip on cutting the paper.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Tapping noise in wall after flushing upstairs toilets John VH Plumbing 2 01-21-2008 11:24 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
