Flexible J Channel For Round Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 11:18 PM   #1
Flexible J Channel for Round Windows
I'm going to be installing a round window in my home which has vinyl siding. Can anyone point me to a source for flexible J channel that will wrap around the window so I can use to re-install the siding? Thanks!
vebe3 is offline   Reply With Quote
Old 09-04-2012, 09:47 AM   #2
try the local siding places for flexible j-channel (not the big box stores, i doubt they have it)
The Following 2 Users Say Thank You to DannyT For This Useful Post:
mae-ling (09-04-2012), vebe3 (09-04-2012)
Old 09-04-2012, 09:52 AM   #3
Rewards Points: 14,026
Do you already have the window? If not it would be best to just order one with the J moulding built in.
Trying to get flex moulding to form a circle will be a real challange.
vebe3 (09-04-2012)
Old 09-04-2012, 10:01 AM   #4
Rewards Points: 2,212
I was able to get a rubbery J channel the one time I needed it. Cost a lot and only came in white at that time, about 12 years ago
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
vebe3 (09-04-2012)
Old 09-04-2012, 07:20 PM   #5
I was able to source something I hope will work:
http://www.specialserviceplastic.com/flex_j.htm
Ordered it today and will have by end of week. Since I'm not close to any siding suppliers ordering online worked out well. I already have window and will be installing it this weekend, will post to let everyone know if product works as described.
Thanks.
The Following User Says Thank You to vebe3 For This Useful Post:
mae-ling (09-05-2012)
Old 10-07-2012, 08:26 PM   #6
This product worked perfectly for my purpose. It is as described by manufacturer, well made and very easy to install.
mae-ling (10-07-2012)
Tags
j channel , round window , vinyl siding
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 07:49 PM
Windows with J channel and Vertical Siding... HELP??? Eesh Building & Construction 1 08-09-2011 03:16 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
J Channel Around Windows EADPellCity Building & Construction 7 07-07-2008 05:48 AM
