Flashing For Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-23-2016, 06:48 PM   #1
Rewards Points: 18
Flashing for Windows
Hey everyone!
I just ripped out the casing and windows of a bedroom of my house. I noticed that when I took them out (I say them because they're twin windows), there wasn't any flashing. Its a brick house, and I may be using the wrong term. I'm talking about the membrane material that you usually see used on wrapping houses during construction. Is that necessary? It wasn't there before, and I don't have water damage of any sort. But I wanna make sure I do it right. I did notice that it was sealed very very well with caulk. Took a lot of effort to get the casing out. Any advice is great! Thanks!
MKMaster is offline   Reply With Quote
Old 08-24-2016, 06:17 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,790
Re: Flashing for Windows
Homes were built, and waterproof, for hundreds of years before peal and stick flashing.
I am assuming that you have a wood framed structural wall with a vented brick veneer. At that point, the flashing approach is a bit different and there are some aspects of this that you cannot repeat based on the the construction being completed already.
Old 08-24-2016, 11:40 AM   #3
Rewards Points: 18
That's awesome. Thanks man. I've seen a lot of windows installations that have a framed opening of 1 x 4 boards. In this case, the window already fits perfectly in the 2 x 4 framing. I guess that's just lucky?
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 12:53 PM
Roof patch job ok or not? daluu Roofing/Siding 8 11-07-2012 09:56 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 05-01-2012 12:42 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 01:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
