Fixing Leaky Skylight - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 09:45 PM   #1
Fixing leaky skylight
One of my skylights has been dripping sometimes when it rains, so I climbed on the roof and found a pretty thick layer of clear silicone caulking along the edge of the glass where it's meets the frame. At the lower right corner of the skylight I found a crack in the silicone, in the same area the drip was happening inside. I ran a hose over the spot on the skylight to confirm this was the problem...and yep, found it.
I've begun removing all of the old silicone to apply new. While doing this I found a layer of black between the glass and the frame, at first I thought it was a gasket/weatherstrip because it was cracking and looked deteriorated, but now I'm thinking it might be some blackjack because the are spots on the corners of the skylight frame that have what appears to be blackjack. See photos below.
My question is should I fill these areas with blackjack, wait for it to dry and go over it with clear silicone? Or should I just seal the whole thing up with silicone and for get the blackjack? Any other suggestions? Thank you!
Fixing leaky skylight-image-2034012971.jpg   Fixing leaky skylight-image-619851663.jpg   Fixing leaky skylight-image-1600373214.jpg   Fixing leaky skylight-image-3079918820.jpg   Fixing leaky skylight-image-2480201406.jpg
mxingislife is offline   Reply With Quote
Old 02-04-2014, 10:36 PM   #2
Rewards Points: 14,312
Time for a new window.
Old 02-04-2014, 11:04 PM   #3
Would a glass shop be able to replace the glass and seal, or would I need to replace the entire skylight? I have a torch down roof, so a skylight replacement would not be cheap.
Old 02-05-2014, 07:03 AM   #4
That black strip looks like the original window glazing.
Hard to tell from those pictures, but if I had to guess the seal may be leaking between the panes as well and the glass is going to start fogging up between the panes of glass if it's "repaired".
Not going to hurt to get a price for a repair, but you may want a warranty in writing.
Old 02-05-2014, 10:42 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
Time for a new skylight.
Do you have some shots from further back?
Old 02-05-2014, 03:26 PM   #6
Originally Posted by Windows on Wash
+1 Time for a new skylight. Do you have some shots from further back?
Here are some pics of the skylight with the silicone removed. I have 4 skylights and they all have silicone caulking so this may be an issue with the others down the road...
Fixing leaky skylight-image-1408824261.jpg   Fixing leaky skylight-image-3899556690.jpg   Fixing leaky skylight-image-2746118978.jpg   Fixing leaky skylight-image-4022541342.jpg   Fixing leaky skylight-image-2497738919.jpg
Old 02-05-2014, 04:13 PM   #7
Metal Roofing
Rewards Points: 600
Looks like a model 2222 (curb mount), you can order a new one through HD from Velux. I think they are under $200. $ well spent imo, not worth trying to fix.
Don't quote me on the Model, take the outside curb dimensions with you when you got to HD.
AndyWRS is offline   Reply With Quote
Old 02-05-2014, 04:21 PM   #8
Are you talking about a whole new skylight? Or just replacing the top portion so no roofing work would have to be involved?
Old 02-05-2014, 04:33 PM   #9
Metal Roofing
Rewards Points: 600
If its a curb mount, which it sure looks like, then no roof work is required.
Self flashing or Deck mount type skylights would require roof work.
I think it was under $300 + tax for a 2222 CM velux at HD, its a completely new skylight, not a replacement part.
http://www.homedepot.com/p/VELUX-22-...z0uh5xZ1z0z1cu
My $200 was a bit off apparently its a bit more, I just checked
oops my bad, I was correct the first time.
This is the one you would need:
http://www.homedepot.com/p/VELUX-22-...0004/202038777
The top link includes a flashing kit which you do not need with a curb mount.
The Following User Says Thank You to AndyWRS For This Useful Post:
Windows on Wash (02-07-2014)
Old 02-07-2014, 07:04 AM   #10
You lucked out depending on how it was installed.
Get a new unit and you should be in good shape for another 20 years (on the skylight front at least).
Fixing leaky Kohler faucet jazzygardener Plumbing 4 11-12-2013 05:04 PM
Fixing leaky 1962 main water valve bighak Plumbing 2 02-21-2013 08:15 AM
Leaky skylight issue - what am I looking at realistically here? GordCooper Roofing/Siding 9 04-06-2012 10:02 PM
Need advice on fixing a leaky elbow on waterline below sink. JeffWireman Plumbing 2 03-12-2010 11:39 AM
Need some advice for fixing a leaky exterior door siuc1996 Flooring 3 08-22-2009 09:55 PM
