Fix A Leaking Basement Window That's Been Filled In From Outside - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 10:09 AM   #1
fix a leaking basement window that's been filled in from outside
We have two basement windows with window wells that were "filled in" on the outside a few years ago with plywood and then the wells were filled with dirt to create a foundation for a large fountain. Now the windows are leaking with heavy rains. How can we fix the leaks from inside the basement, as we can't access it from the outside.
airportlady is offline   Reply With Quote
Old 05-30-2012, 11:15 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
There is no real way to make the window water tight.
You will need to brick/frame up the opening and even then, it might leak on you.
They should have been done differently but I don't want to appear as if I am rubbing salt in an open wound.
Basement window problem B&Kwhippet Building & Construction 6 11-16-2011 12:49 PM
Alum horizontal plane window is leaking. butwhydoitalk2u General DIY Discussions 1 11-01-2011 07:00 AM
basement leaking ptb Carpentry 3 09-12-2011 08:18 PM
Leaking from first floor to basement Deanm Plumbing 7 07-21-2010 05:18 PM
Leaking Window KRyanM General DIY Discussions 1 03-29-2010 06:52 AM
