#1 |
Fire rated doors
Couple days ago it was on tv some guys who improve reg doors to fire rated doors. Is there anybody who knows to explain how to do it. thx in Advance.
Dave H. |
#2 |
Fire rated doors
You remove the old door and jambs and install a door that is fire rated. The rating comes in steps, from 20 min to 2 hrs. The first will be solid core wood doors and frames, the latter will be steel door and frames.
There used to be a practice of nailing a piece of sheet metal to the garage side of the door and that made it a fire door. I don't think that flies anymore. |
#3 |
Super Moderator
Fire rated doors
Just Bill is right---A UL fire rating tag must be on the door or it will not pass inspection.
The frame is part of the fire rating---retrofitting an existing door will not pass.
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| 1 hour fire rated ceiling sith type c 5/8" Gypsum | La Casa | Building & Construction | 0 | 12-11-2010 07:23 AM |
| Can doors installed brick be reversed | FuLLTiLT | Building & Construction | 7 | 01-10-2010 08:52 AM |
| bypass doors | sharonb | Remodeling | 1 | 01-05-2010 11:57 PM |
| Masonite pre hung doors sticking hot weather | Pawl | Carpentry | 4 | 07-08-2008 05:26 PM |
| It's hot outside. Keep the exterior doors and windows closed if running the A/C? | Taylor Crockett | HVAC | 3 | 07-07-2008 06:04 PM |
