Finding A Window Glass Replacement - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 03:46 PM   #1
finding a window glass replacement
i have found some warrenty tags on my windows and i want to find out if i can get replacement double glaze glass. how do i use this information? no name
of the company that made the windows appears.
the tag reads; 120802065 made 7-9-01
factory order 19084
window order 2492 0601
31 3/4 x 37 1/2 white.
window is double pane double hung windows, both move up and down,vinyl coated
Last edited by frnkhtc47; 04-26-2011 at 03:58 PM. Reason: added warrenty tag information/corrected spelling
frnkhtc47 is offline   Reply With Quote
Old 04-26-2011, 10:51 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Well, you've located the serial number, order number, size, and date, unfortunately none of those mean much if you don't know who the manufacturer is. Are there any markings on the glass, spacer, locks, etc?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-27-2011, 07:45 AM   #3
What he said............it really bugs me when manufacturers are so ashamed of their products that they won't put their name on it. Then they tell you what a great product you bought and it has a lifetime warranty........if you can find us.
Old 04-27-2011, 11:13 AM   #4
Too Short? Cut it Again!
Label on bottom edge of window (mirror will come in handy)? Might be on the frame still but that means pulling trim off.
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Basement window replacement topher0524 Building & Construction 7 05-21-2009 03:59 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 12:56 PM
