Filling Interior Door Voids - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 08:41 PM   #1
F-16 DIYer
qslim's Avatar
Rewards Points: 29
Filling interior door voids
I'm going through the house this week and replacing 7 interior doors. For the bedrooms and home office I ordered solid-core prehung units because I work odd rotating hours and I sure would like a little more quiet when I have to sleep off of my family's schedule. Now I have the doors shimmed and hung, but I got the idea here an hour or so ago that I might get a little more quiet if I fill the void between the jamb and the rough opening. I have a couple of cans of expanding foam from another project which I thought would do just great, but I thought a second time that I might not know best and I should check on here first.
Is this foam the best bet? I would be concerned off the bat with it expanding too much and keeping my doors from shutting properly, but if I fill the void with foam and let it cure before I put the backside of the jamb on I'd guess any extra would just spill out and I could shave off the excess before I close it up and finish it... Am I on the right track here or is there a better product for what I'm looking for?
qslim is offline   Reply With Quote
Old 12-02-2013, 08:49 PM   #2
Rewards Points: 12,818
Not going to do much good but it needs to be low expanding foam.
What type heat do you have?
Forced hot air needs a gap under the door for air flow.
Old 12-02-2013, 10:52 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
ive heard countless horror stories about people trying to fill hollow core doors with foam.. the doors warp.. blow apart from the foam expanding... etc.
just replace the doors with solid ones
woodworkbykirk is offline   Reply With Quote
Old 12-03-2013, 05:22 AM   #4
F-16 DIYer
qslim's Avatar
Rewards Points: 29
They are solid. I'm talking about filling the void in the jamb with foam.
Old 12-03-2013, 07:53 AM   #5
http://www.soundproofingcompany.com/...roofing-walls/
Old 12-03-2013, 08:32 AM   #6
Rewards Points: 2,238
If you're going to do that -
make sure the foam is "low-expansion"!
rossfingal is offline   Reply With Quote
Old 12-03-2013, 09:48 AM   #7
PoleCat's Avatar
Rewards Points: 1,638
Foam is a better thermal insulator but transmits sound more than a loose fiber like cellulose or denim fiber.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
qslim (12-03-2013)
Old 12-03-2013, 04:12 PM   #8
F-16 DIYer
qslim's Avatar
Rewards Points: 29
Cellulose fiber, huh? My attic is full of it, I'll pack some in the door jamb here and see how it goes.
Old 12-09-2013, 06:56 PM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 872
Cellulose won't pack.
Just use fiberglass or other batt material.
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-28-2011 12:30 AM
Filling a large hole in basement! rotteneggz Building & Construction 4 10-01-2010 07:11 PM
Filling in old basement door entrance dedward Remodeling 4 07-28-2009 10:46 AM
Filling holes in trim........is it going to be smooth yummy mummy Building & Construction 8 12-07-2008 01:46 PM
