#1 |
fiberglass interior Hollow core door
how do I shorten new interior fiberglass hollow core doors
#2 |
Super Moderator
Sorry--I've never seen a fiberglass interior door--Might want to call the manufacturer for the best methods.--Mike--
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
I just bought them and a friend called them fiberglass, but I didn't choose them for that reason. Whatever the shell, the doors are interior hollow core 6 panel doors that are completely finished. My problem was the process for shortening them requires using wood glue when replacing the plug. If these are not fiberglass I don't know what that material is,
if it isn't wood and isn't porous, should I use another type of glue to make sure it is adhered well. I got them at Lowe's. I'm in SE Texas, near Galv Island. Thank you, hope you can help.
#4 |
Super Moderator
A glue like Gorilla Glue will hold to odd materials. Be careful as it's an ugly color and swells a bit as it cures--wipe off any that gets on the surface of the doors.
A table saw is the handiest tool for cutting new 'plugs' for the door bottoms. Watch your fingers and always use a pusher to guide the wood through the blade.
#5 |
Mod
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#6 |
Super Moderator
Oh, Goody!!! Now we get clear goo all over the place instead of tobacco spit colored!
#7 |
Mod
There is defiantly a learning curve to using that stuff.
They also now have a non-expanding formula but I haven’t tried it yet.
#8 |
Super Moderator
I've only used one or two bottles of the stuff----It has its uses,that's for sure.
Mostly I've had to try to repair the mess left behind after a homeowner used it to "repair" loose crown molding on high end cabinetry.
#9 |
Lowes sells a 6 panel hollow core hardboard door that has a white prime coat on it. Maybe those are the doors. If you cut them off and remove the bottom rail, you obviously need to replace it. It does not require it being a 100% long piece meaning it can be shorter than the opening. You'll be cutting a piece of wood 1 1/8" wide to fill the space and whatever length necessary. I've cut this out of 1x and 2x material and it really makes no difference. You can hold the hardboard open enough to get the rail back in with a coat of glue. Yellow glue is plenty good for this. I avoid Gorilla glue at all costs. Good glue, hard to work with. You can put a small brad at each end of the rail to hold it in place while the glue dries.
Sorry, I just reread yer post and didn't really answer the question as to how to cut them off. I have a straight edge I use that I got at harbor Freight. It's adjustable to any length and has a squeeze type mechanism to hold it in place. I use this as a guide for my circular saw using a plywood blade. If you cut more than 3/4" off of the bottom, you'll more than likely have to replace the bottom rail. Here's the straight edge I use except mine is 6 foot long: http://www.harborfreight.com/hand-to...ide-66126.html Last edited by TrapperL; 08-01-2011 at 10:03 PM. |
#10 |
Super Moderator
Trapper---Nice clamp!
#11 |
Post a photo of the door.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
| Display Modes | |
| Fiberglass door with wood sidelight | JimV | Windows and Doors | 4 | 04-26-2011 12:31 AM |
| Storm door parts? Wood core? Anything but the whole door... | CoconutPete | General Discussion | 2 | 12-02-2010 01:39 PM |
| Why can't I cut hollow core interior door with circular saw? | Brandnewruins | Carpentry | 10 | 07-16-2009 03:56 PM |
