Exterior Window Trim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 06:14 PM   #1
Lightbulb
Exterior window trim
In trimming out my new construction window can I use brick mold all four sides of the window, or are there specific window molds just for windows and the exterior side. Im replacing some old wooden windows, completely taking out the frame and molding to the bare studs.
John M.
jwhit4300 is offline   Reply With Quote
Old 08-01-2012, 08:22 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
brick mold usually goes on both sides and the top for exterior application. The bottom of the window consists of a window seal ( sloped 15 degrees average to the outside )and window nosing connected to the seal to hang out past the vertical plane of the siding.
edit, interior has different trim than exterior. you can have 1x trim on the outside or brick mold, whichever look you want to have for new windows. The window sales guy will supply all necessary info in regards ti trim.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
jwhit4300 (08-01-2012)
Old 08-01-2012, 09:14 PM   #3
thanks
hand drive thanks for the response, that helps!
John M.
The Following User Says Thank You to jwhit4300 For This Useful Post:
hand drive (08-01-2012)
Old 08-02-2012, 10:43 AM   #4
Rewards Points: 13,450
Your going to need Z moulding over the top piece of moulding or water will get in behind it.
jwhit4300 (08-02-2012)
Old 08-02-2012, 04:12 PM   #5
z
Oh yeah thanks for that, I need to plan on getting some of that, or do you think I could make some with some left over metal flashing I have??
John M.
Old 08-02-2012, 08:30 PM   #6
Got a brake to bend it all in one piece?
A whole length 10' long is only about $7.00 you decide.
Old 08-02-2012, 08:33 PM   #7
Framing Contractor
Rewards Points: 118
Check out pvc exterior moldings. Azek is one manufacturer. It can be cut, nails like wood, is easily paintable, and will not rot.
sixeightten is offline   Reply With Quote
Old 08-02-2012, 10:16 PM   #8
Think ill just buy the 10 ft. for 7 bucs!
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
