Exterior Window Finishing - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 03:25 PM   #1
Hello,
I have recently had egress windows installed and the exterior finishing seems questionable by the contractor. Hoping to get some opinions on it. Looking at the picture below, should there be any caulking between the window frame and the wood trim? Is that gap normal? also there is a gap at the siding that is about 3/8" wide and it seems like water can just run down behind the siding.
Thanks!
Brian
eggcrate is offline   Reply With Quote
Old 06-14-2012, 05:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 872
That window should be inset a bit more than the exterior and it should be caulked between the wood trim and the window.
Water runs behind the siding already but that J-Channel is not installed properly either.
I also like a drip cap behind the j and between the wood frame and the siding as a catch and divert.
Old 06-14-2012, 06:01 PM   #3
Thanks for the response.
At this point I don't think the windows can get inset and deeper, though I'm not pretending to know how to install windows. These are egress windows and this particular windows has the bottom half of the window set into the contrete. Seems to me that the wood trim could be taken out and a thicker cut used to make up for the "gap" and then caulked. Again, this was done by a contractor and I just want to know what to tell him. All I know is that asthetically, it really looks bad to me. Not to mention it looks like it's going to leak all over the palce.
What would be your course of action to fix the problems?
Thanks again!
Brian
Old 06-15-2012, 07:06 AM   #4
Rewards Points: 872
Not moving the windows, properly folded J channel, drip cap, and seal the window to the frame.
finishing a basement? what, me worry? itsnotrequired Project Showcase 36 09-18-2012 07:00 PM
Exterior Finishing of a New Constr. Window Install (siding etc.) DefyInertia Windows and Doors 3 04-11-2012 12:29 AM
Normal level of finishing new drywall? MikeKy55 Drywall & Plaster 23 05-21-2011 04:42 PM
Resilient Channels and finishing drywall 9728 Building & Construction 5 06-08-2007 09:32 AM
Finishing nail removal bklauer Carpentry 6 09-05-2006 08:13 AM
