Exterior Slab Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 09:28 PM   #1
Exterior Slab Door
I am installing an exterior slab door. I received the door and the hinge side and the strike side are both beveled.
If I mortise the hinge into the door so the edges are flush on all sides, the hinge will be at a slight angle when the door closed. Or do I mortise the hinge deeper on one side , so it will be parallel with the door jam when the door is closed. or, in other words, do I mortise the hinge deeper on the side opposite the beveled edge so the hinge will be flat when the door is closed.
How would I install the lock? Do I measure the 2 3/8" in distance for the center on the hole on the side opposite of the beveled edge? Won't the beveled edge throw off this measurement?
How do I mortise the striker? Do I have to mortise the side opposite the beveled edge deeper to compensate for the beveled edge. This will also throw off the 2 3/8" distance to the center of the large hole for the handle.
Thank you for your help.
rah140 is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
