Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 06-13-2011, 09:47 PM   #1
Exterior grade basement door???
Does the door from the main level of your home to the basement need to be exterior grade? Trying to sell a home in Lexington County, SC. and the inspector said I have to put an exterior grade door to the basement. When did this become a building code and do I have to comply if my house was built before this date?
stevepersyn is offline   Reply With Quote
Old 06-13-2011, 09:49 PM   #2
Super Moderator
No--However local code might require a fire rated door. That is rare but might be a requirement.
stevepersyn (06-13-2011)
Old 07-01-2011, 04:21 PM   #3
www.doors4home.com
jason.r's Avatar
I had the same scenerio recently. We hung a 1-3/8 door (interior standard) on an exterior jamb set. We included the weather strip, threshold, door shoe to seal out the elements. As basements can be different from the weather outside, they can be another energy leak for your house.
So to be honest with you, I think it's a good idea to install all the accessories that make up an exterior package. Try to use a rabbeted jamb.
Jason
jason.r is offline   Reply With Quote
Old 07-04-2011, 07:32 PM   #4
Green Hat
Not trying to hijack the thread, but I was curious about something in regards to this topic.
I have a basement that is connected to the garage, the garage has a exterior grade door on it for foot traffic, then there are two separate doors going into the basement area. These doors are currently 36" wide. I would like to make one of these 32" if possible, being that I would be able to add a closet next two one of them.
Would this violate code? I will still have one 36" door in the event that big things are moved in and out of the basement.
Thanks in advance!
Andy
Mills314 is offline   Reply With Quote
Old 07-04-2011, 07:37 PM   #5
Super Moderator
That should not be a problem at all----you nasty hijacker
Old 07-04-2011, 08:10 PM   #6
Green Hat
I didn't think so, I just wanted to get some feedback on that issue. I think I could put about anything there to include 70's beads that would be stronger than what is up there right now.........lol
Old 07-04-2011, 08:20 PM   #7
Super Moderator
Beaded curtains---I haven't thought of those in years.
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Adding a door in a basement wall mikewaggo Remodeling 1 05-09-2009 09:35 AM
Basement Bypass door under ductwork Boomer313 Building & Construction 4 12-11-2008 09:17 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
