Exterior Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 02:21 PM   #1
Exterior doors
I have a glass and brick porch off of the back of my house. I would love to upgrade the current doors (they are just screen doors) with a true exterior door for a few reasons. I would like to put in a doggie door on one of them, have a better seal and insulation, better look and have it be able to swing in so I can open in when there is 2 of snow on the ground. The problem is that the rough opening is only 31.5, a little tight for a 30 door (most require a 32.5 rough opening). I would like to get one that is a full lite and the other a half lite (for the doggie door).
Any suggestions on what I can do?
jonmo is offline   Reply With Quote
Old 09-01-2011, 06:22 AM   #2
Energy efficiency becomes useless with a pet door. Otherwise, most new prehung doors fit your description.
The Following User Says Thank You to Just Bill For This Useful Post:
HomeSealed (09-07-2011)
Old 09-01-2011, 07:57 AM   #3
I would get a 30" or a 28" door?
Old 09-02-2011, 06:41 AM   #4
Finding stock entry doors that small will be hard, probably special order. Check the actual dimensions of the frame, some might fit 31.5".
Old 09-05-2011, 10:52 AM   #5
mossypath's Avatar
Just a thought,
What if you were to remove some brick and frame it out for the doggy door. That way you can cover the hole with a foam panel when not in use.
Look at your framing real hard. Can you adjust your opening to receive a 30 inch door?
If you can rework the ruff framing just a little it will save you $$$ on the doors you put in.
Might even reuse the screen doors, to keep that snow from building up on those nice new doors, and rotting out the bottom.
Sorry if Im thinking too far ahead and not answering your? But that is what I would try to do if it was my house.
mossypath is offline   Reply With Quote
Old 09-07-2011, 10:35 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
Many of the custom door manufacturers will make a cut down slab.
That being said, you are going to pay a premium for it and it might be cheaper to do the labor to enlarge the opening.
Old 09-07-2011, 08:48 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Thermatru makes a solid product and their cut-down charges are pretty reasonable. If my memory serves correct, I think that they are usually around $50 give or take.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Tags
door , porch
