-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Exterior doors (http://www.diychatroom.com/f104/exterior-doors-115853/)
jonmo 08-31-2011 03:21 PM
Exterior doors
I have a glass and brick porch off of the back of my house. I would love to upgrade the current doors (they are just screen doors) with a true exterior door for a few reasons. I would like to put in a doggie door on one of them, have a better seal and insulation, better look and have it be able to swing in so I can open in when there is 2 of snow on the ground. The problem is that the rough opening is only 31.5, a little tight for a 30 door (most require a 32.5 rough opening). I would like to get one that is a full lite and the other a half lite (for the doggie door).
Any suggestions on what I can do?
Just Bill 09-01-2011 07:22 AM
Energy efficiency becomes useless with a pet door. Otherwise, most new prehung doors fit your description.
jonmo 09-01-2011 08:57 AM
I would get a 30" or a 28" door?
Just Bill 09-02-2011 07:41 AM
Finding stock entry doors that small will be hard, probably special order. Check the actual dimensions of the frame, some might fit 31.5".
mossypath 09-05-2011 11:52 AM
Just a thought,
What if you were to remove some brick and frame it out for the doggy door. That way you can cover the hole with a foam panel when not in use.
Look at your framing real hard. Can you adjust your opening to receive a 30 inch door?
If you can rework the ruff framing just a little it will save you $$$ on the doors you put in.
Might even reuse the screen doors, to keep that snow from building up on those nice new doors, and rotting out the bottom.
Sorry if Im thinking too far ahead and not answering your? But that is what I would try to do if it was my house.
Windows on Wash 09-07-2011 11:35 AM
Many of the custom door manufacturers will make a cut down slab.
That being said, you are going to pay a premium for it and it might be cheaper to do the labor to enlarge the opening.
HomeSealed 09-07-2011 09:48 PM
Thermatru makes a solid product and their cut-down charges are pretty reasonable. If my memory serves correct, I think that they are usually around $50 give or take.
