Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-06-2012, 09:12 PM   #1
Exterior Door and Uneven Wall
I am replacing an entry door on the front of my house. I did custom order an extended jamb door to give me extra space on the inside for custom trim and wall finishes.
Currently my inside and exterior wall are out of level vertically by 1 degree.
My question is, should I install the door so it is level to the world or level to the walls?
If you do the math with a wall being off 1 degree that puts me at over an inch difference across the length of the door. How the hell am I going to trim a door with exposed jamb at the top and not enough at the bottom?
dcase84 is offline   Reply With Quote
Old 10-06-2012, 09:21 PM   #2
That would be out of plumb, not level.
What type siding do you have?
What's so special about the wall coverings?
As a rule no matter what you have to do that door have to be installed plumb and level or it will always try to close open on it's own and the exposures will be off.
I always just make my own extention jambs to account for out of plumb walls.
Old 10-06-2012, 09:27 PM   #3
I kind of disagree. I would go with the walls on an exterior door.
Tham
Tham is offline   Reply With Quote
Old 10-06-2012, 09:39 PM   #4
Always install the door level and plumb. Make up the difference in installing an extension jamb cut from 0" to whatever you need to have the jamb flush with the interior surface. If the jamb then extends too far outside rip a piece of wood to back the exterior trim. You may also want to have the jamb on the inside extend beyond the wall finish as necessary and rip a piece of wood to back the trim on the inside. You want to have your door not bind against the extension jamb.
If the above is confusing, just install the door level and plumb and then you will figure out the rest. good luck.
TheCamper is offline   Reply With Quote
Old 10-06-2012, 09:43 PM   #5
Yeah, that's what I meant, out of plumb!
I have vinyl siding and currently I have it installed with the brickmould flush with the sheeting at the top, and kicked out at the bottom to get it at true plumb.
I'll be residing in the spring so I'm not too worried about making it look perfect on the outside, I'll get to that, but the inside is going to be a nightmare.
I have some cement board going up on the inside, right over the drywall.
Old 10-06-2012, 09:58 PM   #6
You need to cut a wedged shaped piece of wood for the brick moulding to sit againt so there's no air and water leaks.
Cement board over sheetrock
Why?
Not sure why you think it's such a night mare? Just get the door installed butt the jamb extention up againt the jamb, and scribe a line along the outline of the wall on the extention. Just cut along the line. Sand it and install it.
Old 10-06-2012, 10:00 PM   #7
If you have to rip custom jamb extensions anyway you can rip them to what you need. Jamb extensions on the hinge side kinda suck though.
tham
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 08:49 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 07:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
