Exterior Door Molding Shrinking - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 09:24 PM   #1
Angry
exterior door molding shrinking
My front door has an oval stained glass center, the exterior molding surrounding the oval has shrunk. The store won't help. the glue has melted and there's now a 16th of an inch space between glass and door and spreading. How do I stretch the molding back. i was told a storm door is the culprit because the sun bakes the door. In New England, you need a storm door. I would not have purchased this door if I had known it would melt by the sun and or heat.
jonispicer is offline   Reply With Quote
Old 04-22-2012, 10:35 PM   #2
Rewards Points: 13,270
Is the door also painted a dark color and in direct sun light?
Old 04-22-2012, 10:39 PM   #3
It is bergundy, facing east and gets sun at 2pm
Old 04-22-2012, 11:14 PM   #4
Just about any door company has warnings on the there web site or there was a sticker on the door warning about painting a dark color. As you found out it can distroy some doors.
Adding a storm over it makes what amounts to a solor panel.
Just guessing, is it a steel door? It can melt the insulation inside the door as well as melt the sealer because it gets to hot.
Adding a solor shield film to the glass in the storm door would be one way to stop it from happening agin.
See if you can ID who made the door. Look at the hindges there may be a name right on the hindge. If you can ID the door company you can replace that trim and sealer.
Old 04-23-2012, 10:41 AM   #5
thanks for your response. RB or ReliaBuilt is the name on the hinge.
Old 04-23-2012, 11:04 AM   #6
If you key word search the companys name there should be a list of places selling there doors. Take a picture and some measurements with you.
Anyplace selling storm doors is not likly to tell you about what it's going to do to your door, if they did you would not buy it.
New Home Cracking & Shrinking Problems mmessina1 General DIY Discussions 3 01-12-2010 09:33 PM
shrinking dollar nap Off Topic 5 11-19-2009 12:30 PM
