Exterior Door Leaks At Bottom Corner Of Sidelight - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 10:38 AM   #1
MTW
Exterior Door leaks at bottom corner of sidelight
Hello - I am not sure this is the right place to post. I have attached pictures for your reference. I have an exterior door with 2 sidelights. I have been battling a small leak off and on for several years. If we get a hard wind-driven rain, the door will leak in the bottom left corner of the unit (not at the opening of door itself but under the sidelight between the frame of the house and the floor). The frame of the house gets damp as well as 2 wood pieces underneath the door unit. It does not leak enough to drip into the sill pan.
2 people have looked at the door and cannot find a reason why it leaks. It has been caulked more times than I can tell you and one of the guys said the flashing was fine. It has had new weatherstripping, new sweep, I have adjusted the threshold, messed with the hinges and strikeplate.
It does not leak enough to go underneath to the basement, but I am concerned over time that the wood getting damp will lead to rot. Any ideas would be appreciated! We have thought about getting a storm door, but I want to know if you all think that would solve the problem. Or, if the problem is higher up. The door has no cover and regularly gets sun and rain.
Thanks for the help!
MTW is offline   Reply With Quote
Old 08-17-2012, 10:48 AM   #2
Rewards Points: 13,300
By sill pan do you mean one like this?
http://jamsill.com/
Can you open the door so we can see a picture of what type threshold you have?
Also a close up of where the bottom of the aluminum threshold sits on the brick.
One thing I've done where those side lights are is to add a piece of vinyl cove moulding set in a bed of caulking to help devert the water away from the the bottom of the panel.
Old 08-17-2012, 11:02 AM   #3
MTW
Thanks for taking a look. My terminology on doors is limited at best. The pan I am referring to is under the door and spans the entire unit. It doesn't look like the one you posted. It looks like a thin, long rectangle about 1/2 inch deep.
Here are some more pictures. See if that helps. I am more than happy to send other ones. Thanks again for looking!
Old 08-17-2012, 11:11 AM   #4
That's the threshold, not a sill pan.
Without a real sill pan under that door every place water leaks in will end up hitting the subfloor and rot it out.
All the sealing should have been done under the threshold and up the sides not all over the outside of the threshold.
Not sure who did that caulking job but it's a mess. The way it was applyed it will just funnel water in not keep it out.
Should have been applyed and tooled so it made a curve, not just blobed on and left to dry.
Old 08-17-2012, 11:23 AM   #5
MTW
Sorry for the confusion. I took a picture of the threshold and posted it. I did not take a picture of the pan underneath the door. There definitely is one underneath. No water is getting to the sub floor. Hope that clarifies.
As for the caulking, I assume it needs to be taken out and done again? So, there should only be caulking around the door and where the threshold meets the brick? What type of caulk would you recommend?
In your opinion, do you think the water is coming in because of the crappy caulk job or another reason? Ultimately, my goal is to stop the water from coming in. In my case, doesn't sound like a storm door would help?
Thanks again for your thoughts.
Old 08-17-2012, 11:56 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
have you looked above the door where brick meets wood etc... sometimes the leak travels
hand drive is offline   Reply With Quote
Old 08-17-2012, 01:21 PM   #7
kwikfishron's Avatar
Rewards Points: 186
Pretty simple to troubleshoot the leak with a hose test.
kwikfishron is online now   Reply With Quote
Old 08-17-2012, 02:03 PM   #8
Rewards Points: 150
Sometimes the house settles on the door and starts to back slope the threshold of the door...check that first..especially around the 2 end jambs and also at the center post.
Hammer450R is offline   Reply With Quote
Old 08-17-2012, 02:05 PM   #9
Rewards Points: 150
Open the door and take a pic of the bottom corner of the hinge side.
Old 08-17-2012, 03:15 PM   #10
Rewards Points: 502
http://www.sand-bags.co.uk/?gclid=CK...FUQPfAodzQIAew
tony.g is offline   Reply With Quote
Old 09-25-2012, 12:41 PM   #11
MTW
Sorry I haven't responded sooner. I had some one look at installing a storm door to perhaps fix my problem. But, apparently there is not much to attach it to. Back to square one. I have tried the "hose" test and was able to recreate the leak. I sprayed the hose in the bottom corner where the door meets the lock side (sorry I don't know terminilogy). The leak appeared in the bottom of the sidelight. I have replaced the weather stripping and recaulked. Still nothing. Still leaks. It is beyond annoying.
Someone mentioned the threshold starts to "back slope" if the house settled. I'm not exactly sure what that means. Could I get some clarification?
Thanks again for all of your thoughts.
Old 09-25-2012, 03:36 PM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,926
Theoretically you can build out the jamb and still hang it but that is a decent bit of work.
They also make special frames that are inside mounts as well.
They can be done.
Old 09-25-2012, 04:41 PM   #13
MTW
Hmmm...thanks for your thoughts on the storm door. What company would make the "inside mount" type storm doors? I was originally looking at Provia.
Old 09-26-2012, 07:51 AM   #14
Look at HMI doors.
Patio door bottom sill over brick/concrete block cjf1980 Building & Construction 18 04-12-2012 10:56 AM
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 10:53 PM
How to repair my roof truss - cut bottom chord darlingm Roofing/Siding 10 01-05-2012 08:48 AM
Replacing "wall sole plate" on a corner. CJNut Carpentry 13 12-29-2011 12:03 AM
Vinyl Siding Corner Post Obstruction JDPagel Remodeling 4 04-16-2010 01:46 PM
