Entry Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-25-2014, 08:24 AM   #1
Rewards Points: 99
entry door
I have a question regarding entry door size. I'm having someone custom build a door for me for an addition to an old house -- 19th C Greek revival. the door will be a solid dutch door, with a two pane transom light above, no sidelights. i want a door that will feel appropriate to the house and age, and want something a bit wider than typical. standard is 36" i believe, but what are standard increments to go wider? given he transom I plan on a standard heights i.e. 6'-8". I know a wider door will be a bit unusually proportioned but thats the idea. any insights appreciated!
yellowkid is offline   Reply With Quote
Old 02-25-2014, 12:22 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,592
What kind of look?
Wood...painted...?
Old 02-25-2014, 02:36 PM   #3
Rewards Points: 99
solid wood, painted, 6-panel.
Old 02-25-2014, 03:48 PM   #4
DL's husband's Avatar
As far as what the standard sizes are above 36" No idea.
However, comma, I did some flooring work in the home of a family whose 'matriarch' was about 300 lbs or better and in a wheel chair. Their front and side doors were 40"(?) if I remember correctly. Not positive about the door size but I know they opened out.
Craig in southeastern Virginia
Navy veteran July 1980 - August 2007
DL's husband is offline   Reply With Quote
Old 02-25-2014, 03:58 PM   #5
kwikfishron's Avatar
Rewards Points: 1,022
Door widths typically go up in 2" incriminates.
kwikfishron is online now   Reply With Quote
Problem installing entry door Jemo Building & Construction 19 09-13-2015 07:50 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
HELP -- Entry front door suggestion Ddebal General DIY Discussions 2 09-01-2009 07:08 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Considering Pocket Entry Door at top of stairs snsdiy Remodeling 6 01-06-2009 06:39 AM
