Entry Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 01:40 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Entry door
He two screws that hold my latch in place on my door is stripped and they back themselves out and then we have to screw them back to be able to shut the door,
Last time I had it apart, I remember the wood around the latch to be chewed up, so I don't think the "goft tee" trick would work. I already put in a bigger screw in.
Is there anything else I can do or do I need to get a new door??
And if I do put another entry door in, can I do just the door, so I don't have to go through all the work of putting in a new frame??
Thanks Barry
Barry J is offline   Reply With Quote
Old 02-10-2012, 02:11 PM   #2
Rewards Points: 2,210
You can drill the holes out and put in dowels. Also you could try and use epoxie glue on them.
mae-ling is offline   Reply With Quote
Old 02-10-2012, 02:30 PM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
The dowel trick is the same as the golf tee trick.
When I had the door knob out, the wood on either side of the screw holes was all the way through to the latch hole,
So placing a golf tee in the hole is like putting it into a hole that is "c" shaped. Does that make sense??
Barry
Old 02-10-2012, 03:23 PM   #4
Pics may help, if you can.
Can you drill it out so it is round?
If not.
Pack the hole with toothpics and glue, and screw in before glue sets.
Old 02-11-2012, 08:47 AM   #5
A door a day is all I ask
TheDoorGuy's Avatar
I only have a couple of things that I have used successfully in you situation.
The first is pretty annoying and labor intensive. I mortise out the area where the the latch face plate sits about 1/2" deep.
Then I cut a piece of oak or fir (or other fairly hard wood) 1/2" x 2 1/4" x 1" and glue it into that deep mortise using devcon 5 minute epoxy.
When that is dry (Devcon says 1 hour for full strength but I usually cheat and move on in 10 minutes or so), I drill the 1" latch bolt
hole and mortise in for the face plate 1/8" then pre drill 1/8" holes for the screws and reinstall latch and lock. Like I said, it's a pain but does work.
The second solution is more down and dirty. Using about 7/64" steel drill bit I drill at a fairly steep angle through the screw holes
up and down into the solid portions of your door. Then using a slightly thinner (maybe an #6) and longer sheet metal type screw I hold the
latch in place and drive screws in at the angle. They don't seat flush but the small size of the scew head usually lets them seat
far enough in so they are not a problem.
I hope that helps you avoid buying a new door!!
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 02-11-2012, 08:51 AM   #6
Rewards Points: 13,300
If your talking about the latch plate that's on the jamb just use a longer, not a bigger screw. If it's the latch bolt plate the same thing should work. Far less work.
Problem installing entry door Jemo Building & Construction 19 09-13-2015 08:50 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
HELP -- Entry front door suggestion Ddebal General DIY Discussions 2 09-01-2009 08:08 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
Considering Pocket Entry Door at top of stairs snsdiy Remodeling 6 01-06-2009 07:39 AM
