Encore Windows From Seaway? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-27-2015, 07:44 PM   #1
Rewards Points: 83
Encore Windows from Seaway?
Anyone have any experience with these? Information is very limited on the internet for these replacement vinyl windows. Just found out a neighbor sells them. He gave me a pamphlet and they advertise some very good performance numbers. .01 air infiltration( not .1 but .01) on a double hung and even their most bottom line has .26 u factor ( and it gets down to the teens for their triple pane top of the line).
Trying to figure out how these compare with the Plygem Premiums that i have been looking at using. Any experiences with Seaway let me know. Thanks.
AllGoNoShow is offline   Reply With Quote
Old 04-28-2015, 07:10 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
Good to see you over here as well.
Can't add much to the discussion that wasn't already discussed over on the other site.
Post up a link and maybe you will get some more feedback.
Old 04-28-2015, 09:27 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Can't say that I have installed the product personally, but the numbers look good. I would cross-reference the u factor with SHGC and condensation resistance to ensure that those numbers aren't achieved with "side-effects", meaning improper low e coatings for your climate. If it has an shgc over .25, VT near or over 50, and CR in the 60's or better to go with that u factor, it sounds like a legit performer.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (04-28-2015)
Old 04-29-2015, 07:17 PM   #4
Rewards Points: 83
Heres a link to the windows: http://www.seawaymfg.com/products/vi...-hung/anatomy/
Old 04-30-2015, 03:54 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
not a ton of info on the website, but the nfrc sticker that they show has a .20 u factor with triple pane krypton. While that is a very good u factor, it is NOT impressive at all with krypton. By comparison, other products achieve u factors around .15-.16 with the same glass... Ultimately, that leads me to believe that the numbers above are not legit. I also noticed that they make mention of "glass only" ratings on the website. These numbers are completely irrelevant to you as a consumer, and are generally used to confuse and mislead you, since the NFRC only tests total unit u factor.
All that said, they have over 200 pages of glass packages tested on nfrc.org. I'd suggest asking for the CPD number of this glass package so that you can get the real facts on it. (you reference that number on nfrc.org)
www.HomeSealed.com
Old 05-02-2015, 09:49 AM   #6
Rewards Points: 83
The pamphlet they gave me says the triple pane with krypton is .15 u factor (the triple pane with argon is .20). The bottom end window with double pane argon is listed as .26 NFRC whole product u factor and .26 shgc. An upgrade to the "super spacer" makes it .25/.26. The same literature gives the .01 air infiltration number on a double hung window.
The plygems premium with just the normal hp low e/argon package are .29 u factor and .27 shgc and .51 vtl (the encores do not have a vtl listed).
Considering there is just a lack of info on the Seaways i am prolly just gonna go with the Plygems. At least i know what i will be getting ( a solid B grade window at a reasonable price). Ive looked at some of the other manufacturers recommended and they either dont sell in western ny or there only dealers in the area do installs and will not sell for dyi.
Old 05-05-2015, 03:08 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'd take a minute to research this further. Every year that goes by the plygem offerings slide down further on the grading curve. Average is about right IMO.
Like I mentioned previously, I'd ask the Seaway guy for the CPD number on the product that he is quoting so that you can verify whether it is a real performer or a pretender. If its legit, like I said earlier, those numbers are very good. Post back with that info if you get it.
www.HomeSealed.com
Old 05-27-2015, 09:21 PM   #8
Rewards Points: 83
I got a CPD number for the one with the super spacer. Apparently the numbers they cite in their brochure are for windows with several upgrades. For the basic Insulglaze 450s with the super spacer it is .29 u factor, .25 shgc, .46 VT, 59 condensation resistance.
For comparison the PlyGems are .29, .27 shgc, and .51 VT. I can't seem to find anyone online that has anything bad to say about the Seaways, there just isn't a lot out there about them.
Old 05-28-2015, 08:15 AM   #9
Those numbers at just pretty average.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (05-30-2015)
Old 05-30-2015, 09:29 AM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. Average thermals.
I'd look to the air infiltration and design pressure ratings to separate those two.
www.HomeSealed.com
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
69 year young lady struggling with windows robaire Windows and Doors 6 01-18-2012 07:01 AM
Sunrise or Seaway Windows Joe Dirt Windows and Doors 6 01-06-2012 09:27 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 06:25 AM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
