egress windows
It seems like everyone that responded to this question read it differently, lol... The above post is correct. Every basement room that is to be considered a bedroom needs one window that meets egress code requirements. If you have more than one window in a given room, only the one has to meet the requirement, but that one window does not suffice for other, separate rooms in the basement.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
