Egress Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 04:30 PM   #1
egress windows
what size openings must have egress windows
Clement is offline   Reply With Quote
Old 08-15-2011, 04:35 PM   #2
Experienced
Jackofall1's Avatar
Welcome Clemet, to the best darn DIY'r site on the web.
What does your local code call for? There will also be a max heigh from the floor I am sure.
Mark
Old 08-15-2011, 04:37 PM   #3
kwikfishron's Avatar
Rewards Points: 818
According to International Residential Code (IRC), an egress window must satisfy four criteria:
Minimum width of opening: 20 in.
Minimum height of opening: 24 in.
Minimum net clear opening: 5.7 sq. ft. (5.0 sq. ft. for ground floor).
Maximum sill height above floor: 44 in.
The window must have a minimum net clear opening of 5.7 sq. ft. Net clear opening refers to the actual free and clear space
that exists when the window is open. It is not the rough opening size or the glass panel size, but the actual opening a person
can crawl through.
The window opening must be operational from the inside without keys or tools. Bars, grilles and grates may be installed over
windows but must be operational without tools or keys and still allow the minimum clear opening.
copied and paste
kwikfishron is online now   Reply With Quote
Egress window question - Andersen windows comply? tpagel Windows and Doors 7 06-25-2011 08:40 AM
Installling Basement Egress Windows JohnnyB Building & Construction 2 04-11-2010 07:15 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Windows: RO sill height and egress question. iMisspell Building & Construction 3 10-25-2008 12:55 PM
