Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-06-2012, 08:07 AM   #1
egress window questions
We are planning on converting an area of our basement to a bedroom, we know in order to do this we need an egress window. We also have a bar area and living room area & office area in our basement.
My question is if the window is in the bedroom, would the bar area and living room area & office area be able to be considered living space as far as sq footage if and when we decide to sell?
oreopop17 is offline   Reply With Quote
Old 07-06-2012, 08:58 AM   #2
creeper's Avatar
Not in my area. It would have to mentioned in the text part of a listing. For example: 2400sq. ft bungalow with an additional 1000 sq finished basement w/ living rm., bar and office.
You couldn't say 3400 sq ft for sale.
Ask a local Realtor
creeper is offline   Reply With Quote
Old 07-06-2012, 09:11 AM   #3
I guess my question is as it stands now even though the basement is finished none of it is considered living space. So if an egress goes into the bedroom is that enough to cover the entire basement or would i need one in non bedroom area as well.
Old 07-06-2012, 09:19 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Check with your local AHJ. They will tell you if just the one will cover the whole basement area, or if you should add a second form of egress, whether it is a door out, or another window.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Window replace/install questions... bcbud3 Remodeling 2 04-06-2010 06:21 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
