Egress Window Question - Andersen Windows Comply? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 08:30 PM   #1
Rewards Points: 256
Egress window question - Andersen windows comply?
I want to replace some windows in an upper floor which might be used for bedrooms sometime in the future. I want to install a couple egress windows. The rest of the house uses Andersen 400 Series casements. Do these windows comply with code for egress windows, if they are the right height and width, I mean, do I need to order special hardware to let the window swing clear away from the sash? I continue online research, but if somebody knows off the top of their head, I would appreciate the feedback. Thanks in advance
tpagel is offline   Reply With Quote
Old 06-21-2011, 08:51 PM   #2
firehawkmph's Avatar
Rewards Points: 1,792
Tp,
Andersen should have all that info on their site. From what I remember, when I was building homes in Ohio a number of years back, the casement windows had to have a net opening width of 20 inches. Some of andersen's hardware helps this out by moving the pivot point of the window as it opens to increase the clear width. Check with your local building department before you do anything. They should be able to provide you with what they require. Then just doublecheck with Andersen.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-21-2011, 09:27 PM   #3
concretemasonry's Avatar
Rewards Points: 2,566
Any Anderson window that qualifies as an egress window will have a sticker on it.
Dick
concretemasonry is offline   Reply With Quote
Old 06-21-2011, 09:43 PM   #4
KemoSabe
loneframer's Avatar
Andersen casements do have windows that meet Egress requirements, although not all do. The windows marked with a diamond meet egress standards
http://www.andersenwindows.com/servl...&ssbinary=true
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 06-21-2011, 10:07 PM   #5
Concrete & Masonry
Rewards Points: 468
Dick
...and it should be denoted as such in just about any brochure they put out. Just read the fine print of the brochure to see what they use for a label......
jomama45 is online now   Reply With Quote
Old 06-21-2011, 10:09 PM   #6
Rewards Points: 256
thanks for all replies. Much appreciated
Old 06-21-2011, 10:41 PM   #7
If you have an inspection, leave the sticker on the window to eliminate any confusion or lost paperwork in case you do not have the current brochure handy. - Make sure your sill height meets the local requiements since a locality can have a different/tougher standard and my friend had to get the inspection after the laminate floor was installed to decrease the sill height for kids to egress.
Dick
Old 06-25-2011, 09:40 AM   #8
Custom Home Builder
Very simple.
Go to your local supplier and ask for a catalog.
Egress will be noted on the casement page.
thomasjmarino is offline   Reply With Quote
How to choose new windows? secutanudu Windows and Doors 25 05-15-2014 06:57 PM
Marvin vs. Andersen Windows GinoS Building & Construction 2 06-22-2011 11:25 AM
window performance question renbelle Building & Construction 4 10-06-2010 03:25 PM
Window AC with double windows regal55 HVAC 3 06-05-2010 02:34 PM
Egress Window Questions? cibula11 Building & Construction 12 03-15-2007 01:24 PM
