Is This An Egress Window? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-06-2014, 02:49 PM   #1
Rewards Points: 206
Question
Is this an egress window?
We are renovating our garage into living space, including a new bedroom.
The existing window in the new bedroom is currently double hung, vinyl. Both the lower and the upper sashes can be removed.
If both sashes are removed, there is a clear opening 27" wide and 33" tall and starts 35" above the floor.
So, with the sashes removed, this would meet the 5 square foot, ground floor requirement.
The question is, would having to remove both sashes be considered too time consuming or cumbersome?
John_W is offline   Reply With Quote
Old 07-06-2014, 03:00 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
I believe most/all BO's are going to expect clear opening space with the windows natural operating system.
Otherwise, you could pop windows out of sliders etc. I have had BO's question the clear opening of a casement window frame blocking the clear opening when swung out.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
jomama45 (07-06-2014)
Old 07-06-2014, 03:11 PM   #3
Rewards Points: 206
Thanks for commenting.
By natural operating system do you mean without having to remove the sashes?
Old 07-06-2014, 03:20 PM   #4
yes.....
Old 07-06-2014, 03:34 PM   #5
Rewards Points: 960
The replies you are getting are correct.
I imagine over 90% of people could not remove the sashes on a slider or double hung in any amount of time. I wonder how many would be smart enough to get out with the screen in place?
As for the exterior entrance, an axe or wrecking bar will open up a casement, double hung, or slider equally well.
cleveman is offline   Reply With Quote
Old 07-06-2014, 03:42 PM   #6
Rewards Points: 206
yes.....
The next step then would be to replace the double hung with a casement.
You said even these can run into trouble.
Are there particular parts on a casement that, if present, will show that the casement can be swung out at least 90 degrees quickly and would be more-or-less fool proof to operate in an emergency?
Old 07-06-2014, 03:52 PM   #7
concretemasonry's Avatar
Rewards Points: 2,654
John W -
How is a 5 year old able to remove the sashes?
there are two main points for egress windows -
1) The maximum height of the sill must be the correct amount above the finished floor. This is usually 42" to 44", but there could be changed from the minimum standard by local authorities. In our area, we have the largest population of Hmongs (short in stature only) and there was a proposal to change the minimum allowable open sill height to 40" in the interest in life safety. - This is just an installation situation and existing installations are grandfathered.
2) The window itself is usually available and has a manufacturers certificate on it that really should be kept as long a possible to avoid any questions. The standards for the window units are determined by building officials, fire department representatives and insurance companies and the always present public groups. - This addresses the consensus for exiting residents (young and old) and to allow fire fighting with the usually hardware (hats,visors, tanks) necessary. The window must provide access without tools to remove parts (hinges, stops and casement operators).
If you have a particular situation on a remodel, it is best to get an opinion from a building official since they do not want any problems. - Fortunately, the inspection departments are not a profit that makes money from problems that raise their costs.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
John_W (07-06-2014)
Old 07-07-2014, 11:33 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Everybody else nailed it. Needs to be normal operation of the windows.
Old 07-07-2014, 12:30 PM   #9
Windows on Wash..... I can't just leave my sawsall and bulldog plugged in by the window....
Windows on Wash (07-07-2014)
Old 07-07-2014, 02:18 PM   #10
Concrete & Masonry
Rewards Points: 636
There are also a number of different egress windows where the sash swings completely open, so a smaller window still meets the requirements Here's an example of a small "double hung" that meets egress requirements:
http://www.redi-exit.com/egress-wind...wing-p-51.html
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
MTN REMODEL LLC (07-07-2014)
Old 07-07-2014, 02:46 PM   #11
Rewards Points: 2,080
By all means NO. It must be cordless in the event the AC power has failed. Battery dead as always? Tuff luck.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 07-07-2014, 04:46 PM   #12
Rewards Points: 206
Thanks very much.
I was hoping to get manufacturer make/model info like this.
Hopefully they make a window that will fit my opening.
Old 07-07-2014, 05:49 PM   #13
Jo.... Interesting.... never seen/knew of....good to know.
Old 07-07-2014, 08:16 PM   #14
firehawkmph's Avatar
Rewards Points: 1,922
When I was building houses back in the 90's, if I remember correctly, double hung windows needed 5.7 square feet of net opening, and a casement in addition had to have a net width opening of 20". Manufacturers were starting to offer egress hardware on casements that would move the pivot point of the sash over to the side as it opened. Andersen use to have all the specs in the catalog and online site. Shouldn't be hard to find.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-08-2014, 08:41 AM   #15
Rewards Points: 206
Mike Hawkins
Thanks.
Stair headroom and egress window permitting Cutiger26 Building & Construction 9 04-20-2014 09:56 PM
egress window help oba97 Building & Construction 5 05-27-2012 09:00 PM
egress window terrytoo Building & Construction 3 11-11-2010 05:47 AM
egress window kikipauw Building & Construction 3 11-10-2010 06:30 AM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 11:15 AM
