Easiest Way To Remove Bottom 1/2" Of Jamb/casing Of Split Jamb BEFORE Hanging Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 08:15 PM   #1
Dave88LX's Avatar
Rewards Points: 566
Easiest way to remove bottom 1/2" of jamb/casing of split jamb BEFORE hanging door?
I have finished hardwood floors, I'm installing new doors with a split jamb. I think next time I will get flat jamb and just case them after since it's not very difficult.
What is the easiest way to get a consistent accurate cut through all the jamb and casing?
Don't say pull saw after I install it. I have finished floor in place, I need to trim them before I install them.
Thanks in advance!
- Dave
Dave88LX is offline   Reply With Quote
Old 02-12-2013, 08:21 PM   #2
DIY staff
Rewards Points: 7,174
Make a saw guide by screwing two scraps of plywood into an L shape---clamp that the the jamb--let the other side hang over the casing----use a circular saw with a good sharp blade.
Dave88LX (02-12-2013)
Old 02-12-2013, 08:43 PM   #3
Davejss's Avatar
Rewards Points: 760
I would use a good sharp hand saw.
Davejss is offline   Reply With Quote
Old 02-12-2013, 11:13 PM   #4
Dave88LX's Avatar
Rewards Points: 566
Awesome idea, I didn't think of that. I was using something similar to make weird cuts in plywood with a circular saw. I'll have to try this method if I have any more split jamb doors. I'm very UNimpressed with the quality and squareness/warpage/gap. What should you expect out of a "finished" door for $58 though.
Front door not hanging straight aGrandma Windows and Doors 8 09-30-2014 11:57 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
hanging Mirir on door txmike Carpentry 9 08-02-2009 09:01 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Help hanging a problematic door Termite Carpentry 12 07-21-2008 07:05 PM
