-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Easiest way to remove bottom 1/2" of jamb/casing of split jamb BEFORE hanging door? (http://www.diychatroom.com/f104/easiest-way-remove-bottom-1-2-jamb-casing-split-jamb-before-hanging-door-171810/)
Dave88LX 02-12-2013 08:15 PM
I have finished hardwood floors, I'm installing new doors with a split jamb. I think next time I will get flat jamb and just case them after since it's not very difficult.
What is the easiest way to get a consistent accurate cut through all the jamb and casing?
Don't say pull saw after I install it. I have finished floor in place, I need to trim them before I install them.
Thanks in advance!
- Dave
oh'mike 02-12-2013 08:21 PM
Make a saw guide by screwing two scraps of plywood into an L shape---clamp that the the jamb--let the other side hang over the casing----use a circular saw with a good sharp blade.
Davejss 02-12-2013 08:43 PM
I would use a good sharp hand saw.
Dave88LX 02-12-2013 11:13 PM
Awesome idea, I didn't think of that. I was using something similar to make weird cuts in plywood with a circular saw. I'll have to try this method if I have any more split jamb doors. I'm very UNimpressed with the quality and squareness/warpage/gap. What should you expect out of a "finished" door for $58 though.
