Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 02-13-2012, 06:25 PM   #1
dumb question. door knob
i bought a new bed and bath atlas door knob with a lock to match the others in the house. i never thought about this before but when i installed it... the inside lock(the turning button) when it is horizontal it is locked and when i turned it clockwise it is vertical it is unlocked. that is the opposite of my other doors and most houses i have been in. usually horizontal is unlock and then turning it counterclockwise locks it. im pretty knowledgeable with this kind of stuff but this is weird to me as i havent done much with door knobs before.
jhack836 is offline   Reply With Quote
Old 02-13-2012, 06:38 PM   #2
im guessing every brand is different.
Old 02-13-2012, 06:41 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
take the two screws out and turn the knob?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-13-2012, 06:42 PM   #4
Old School
Willie T's Avatar
On most locks, you can often either remove and reset the extension shaft 90 degrees... or they have some other provision for rotating the connecting setup to get the "standard" and normal position for the button.
Yes, vertical is usually unlocked, and horizontal is locked.
With some cheap locks, you are just stuck with what they sell you.
Willie T
Old 02-13-2012, 07:24 PM   #5
it is a brand new atlas door knob. is it a pain to reset anything, it isnt a big deal really but now im curious
Dumb Question cgoll HVAC 13 03-28-2011 12:24 AM
Dumb question, how do you twist your wires together? Piedmont Electrical 62 04-13-2010 03:50 AM
Dumb HVAC question... 737Pilot HVAC 6 11-03-2008 04:56 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Dumb Siding question 1610 CUB Building & Construction 4 08-23-2008 05:08 PM
