Drilling Out A Larger Hole For A New Lock... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 03:37 PM   #1
Ironlight's Avatar
Drilling out a larger hole for a new lock...
I'm replacing the lock on my front door (double deadbolt because the door has beveled glass panels in it). The existing hole is around 1 7/8" and the new lock needs a 2 1/8" hole. Is there some neat trick for centering the larger hole saw on the existing hole since you don't have the benefit of anything for the pilot bit to drill into?
I figured someone here might know a way I might never think of...
Ironlight is offline   Reply With Quote
Old 03-01-2012, 03:46 PM   #2
Civil Engineer
Rewards Points: 4,522
You need to cut out a plug to fit the old hole. This would be 1-7/8 inch diameter, you may need to wrap a piece of paper around it to get it to fit tight in the hole. You use the plug to allow the pilot for the new hole to grab.
Old 03-01-2012, 03:59 PM   #3
Ironlight's Avatar
That means getting a new hole saw. ARGH I was just at the hardware store, lol.
Thanks Daniel, that sounds like a plan.
Old 03-01-2012, 04:28 PM   #4
Rewards Points: 12,868
Take a piece of OSB, Plywood, 1 X whatever you have laying around and hold it so it's flush with the side of the door. Draw a circle where the old hole is.
Find the center of that hole and mark it.
Bore the scrape piece with the 2-1/8" hole saw. Now just screw it to the door making sure it's centered with the old hole. Now bore your 2-1/8 hole using the scrape pieces as your saw guide.
Old 03-01-2012, 04:58 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Thats a good idea Joe.... although I'd suggest clamps if you don't want screw holes in your door.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-01-2012, 05:25 PM   #6
Quick grip clamps may woudl with out any damage. I forgot to add to put the screws where the knob trim would cover it up so no repairs would be needed.
HomeSealed (03-01-2012)
Old 03-01-2012, 05:42 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Right on.
www.HomeSealed.com
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 11:06 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 11:16 AM
