-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Drilling out a larger hole for a new lock... (http://www.diychatroom.com/f104/drilling-out-larger-hole-new-lock-135593/)
Ironlight 03-01-2012 02:37 PM
I'm replacing the lock on my front door (double deadbolt because the door has beveled glass panels in it). The existing hole is around 1 7/8" and the new lock needs a 2 1/8" hole. Is there some neat trick for centering the larger hole saw on the existing hole since you don't have the benefit of anything for the pilot bit to drill into?
I figured someone here might know a way I might never think of...
Daniel Holzman 03-01-2012 02:46 PM
You need to cut out a plug to fit the old hole. This would be 1-7/8 inch diameter, you may need to wrap a piece of paper around it to get it to fit tight in the hole. You use the plug to allow the pilot for the new hole to grab.
Ironlight 03-01-2012 02:59 PM
That means getting a new hole saw. ARGH I was just at the hardware store, lol.
Thanks Daniel, that sounds like a plan.
joecaption 03-01-2012 03:28 PM
Take a piece of OSB, Plywood, 1 X whatever you have laying around and hold it so it's flush with the side of the door. Draw a circle where the old hole is.
Find the center of that hole and mark it.
Bore the scrape piece with the 2-1/8" hole saw. Now just screw it to the door making sure it's centered with the old hole. Now bore your 2-1/8 hole using the scrape pieces as your saw guide.
HomeSealed 03-01-2012 03:58 PM
Thats a good idea Joe.... although I'd suggest clamps if you don't want screw holes in your door. :thumbsup:
joecaption 03-01-2012 04:25 PM
Quick grip clamps may woudl with out any damage. I forgot to add to put the screws where the knob trim would cover it up so no repairs would be needed.
HomeSealed 03-01-2012 04:42 PM
Right on.
