Drilling Additional Holes On The Frame Of A Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 09:16 PM   #1
Rewards Points: 1,656
Drilling additional holes on the frame of a window
There are some predrilled holes on the inside edge of the aluminum window I am installing.
According to instructions, I am using long 3/16" Tapcon screws to go through the 1x buck into the concrete block.
On two of the holes, must be my luck, the drill bit wouldn't advance far into the block. In fact my Tapcon bit broke off. I am thinking I am hitting rebars inside the block, which is common on blocks on edges of windows and doors.
Is it OK for me to drill a new hole through the metal frame, to have a new spot for the Tapcon?
miamicuse is offline   Reply With Quote
Drilling into a vinyl casement window rmh@newburgh Windows and Doors 2 11-10-2012 06:28 AM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 06:24 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
