Drafty Wood Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 08:40 AM   #1
Drafty Wood Windows
We recently moved into a 75 year old house with original wood double-hung windows. They are beautiful and in excellent condition and I do not want to replace them, but they are a bit leaky. I was considering thin weather stripping at the bottom of the sash or on the window sill and perhaps some where the 2 rails meet. I think these are the 2 areas leaking the most. Is this the way to go or is there a better solution? Also there is a little play in the vertical channels that the windows slide in, probably from wear. I think this would be harder to address, any ideas would be appreciated. Thanks, Rick.
rick2443 is offline   Reply With Quote
Old 12-13-2011, 08:59 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Install storm windows. Is there any glazing involved?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-13-2011, 09:19 AM   #3
We have aluminum storms which for now are OK, I may consider replacing them in a few years.
Old 12-13-2011, 10:51 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'd agree. I've not come across any retro fit weather stripping measure that offer an acceptable level of fit and finish or durability. If you have storm windows that are in acceptable shape, then make sure that every thing is caulked and sealed properly. I've had good luck with a high-quality storm for my clients that didn't want to alter the look of their home with a replacement window. You could even look at some of the interior storm options out there for the winter months.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 10:37 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
White vinyl windows with wood trim... crazy? rnjsbungalow Interior Decorating 5 04-16-2009 05:53 AM
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 06:33 PM
