Draft Under Threshold - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 11:02 PM   #1
Draft under threshold
So it appears that there is a draft coming from under the threshold. I have checked several times and there is no draft from between the door bottom and the threshold.
The threshold looks similar to this: http://www.homedepot.com/p/Frost-Kin...C36A/100140107
Do I need to caulk the joints (interior/exterior) of the threshold?
Or do I need to replace it altogether?
I recently bought his house and although the threshold looks to be in decent state, I have no idea how old it is.
mrchief is offline   Reply With Quote
Old 01-29-2014, 11:40 PM   #2
Rewards Points: 14,312
There was suppose to be flashing and silicone under the door when it was installed.
Post a picture inside and out of the door.
Windows on Wash (01-30-2014)
Old 01-30-2014, 03:02 PM   #3
Sure. Will do once I get home...
Old 01-30-2014, 04:23 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Should have been sealed underneath as Joe said or spray foamed.
Old 01-30-2014, 04:25 PM   #5
http://www.bing.com/images/search?q=...electedIndex=4
Old 01-31-2014, 07:58 PM   #6
Sorry about the delay.... Here are the pics
The Following User Says Thank You to mrchief For This Useful Post:
gregzoll (02-01-2014)
Old 01-31-2014, 09:42 PM   #7
Well for one thing that white piece on the outside doing nothing but forming a funnel for water to get in behind it.
The door was suppose to be installed with the jambs even with the outside sheathing.
Done that way the threshold would have been sticking out behind the sheathing by about 1".
A solid piece of something 3/4 thick goes under the threshold, not against the face of it.
I like to use a piece of PVC lumber. The ones I buy are smooth on one side and wood grained on the other.
Like this.
http://www.bing.com/images/search?q=...lectedIndex=57
Old 01-31-2014, 10:13 PM   #8
Rewards Points: 6,652
Can you post real pictures, not thumbnails.
Old 01-31-2014, 10:39 PM   #9
Gregzoll if you tap the right hand picture it comes up bigger. The other ones do not.
Old 02-01-2014, 12:32 AM   #10
Temp. fix, just go get a Door sock from Lowe's, Home Depot, Ace Hardware. They have three sacks of Kitty Litter in them, to weight them down, so you can place them against the door when it is closed.
We use them in our house at our two doors, and they work very well. Come Spring though, you need to fix the problem with the door, due to not being installed correctly to begin with.
That may mean tearing it completely out, to replace with a whole new unit.
Old 02-01-2014, 09:07 AM   #11
Switched to bigger thumbnails.
Also fixed rest of the links. Click on the thumbnails to bring up the original hi-res image. Sorry about that!
Old 02-01-2014, 09:12 AM   #12
Like this.
The white thing is a metal casing, to cover up the concrete I guess. Its wobbly and I want to replace it because I fear someone's gonna slip stepping on it and its gonna come out then. But I don't know what should I replace it with, or how to replace it myself.
Water is not so much of an issue because this entry door is in my garage.
Old 02-01-2014, 11:22 AM   #13
I got some more (and hopefully clearer) pics:
Top view:
Closeup:
Front view:
Close up:
Wearing out caulk maybe letting in some air thru the corners. The out of shape metal was I think meant as a first defense against the surrounding wood and threshold bottom.
It seems to be in good shape, maybe adding a bead of caulk (where the black meets the floor) might help?
P.S. The tape inside was my temporary fix in this freezing cold.
Old 02-01-2014, 12:28 PM   #14
First thing, those shipping pieces at the bottom, need to be removed. They should not still be there. They are only for keeping the door in place, while it is being shipped from factory to store.
Old 02-02-2014, 07:28 AM   #15
Gotta pull that aluminum off and see what is under there. You can probably shoot some low expansion foam and get a better seal on the under side.
Gregzoll...maybe it is pre-coffee but what parts are you referring to?
Replace threshold? thaKing Windows and Doors 4 07-17-2012 11:27 AM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
New Door with Wood Threshold Over Limestone BigJimmy Building & Construction 1 02-08-2008 05:36 AM
Threshold problem from bedroom to patio Not Sure Carpentry 11 11-07-2006 07:16 PM
