Double Or Triple Pane - Worth It? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 10:32 AM   #1
Rewards Points: 160
Double or Triple Pane - worth it?
I am deciding between double pane windows from a company Mitten - their Grand River vinyl double pane windows for $8000
vs Triple pane windows from a company that locally makes the windows in house, and have an excellent reputation for $12,000.
House build in 70's, bungalo style.
Some say this, some say that, sure I'd like triple pane...but $4000 bucks is a lot of money.
Some say double will fog or have moisture, others say triples will be heavy - especially the big picture window and my 2x4 house wasn't built for that weight.
Like anything...what is the best info to trust???
I live in Canada...
hellothere123 is offline   Reply With Quote
Old 02-16-2012, 10:44 AM   #2
Rewards Points: 13,458
Both style windows can fog up if the seal is broken.
Weight should not be a factor.
2 X 4's are strong enough to hold up a whole roof system, why would they not be strong enough to hold up a simple window?
Are these replacement widows, or new constrution?
Old 02-16-2012, 02:50 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,164
+1 to joe's advice.
A failed window will fog regardless of double pane or triple pane.
There is no difference in the weight ability to support a window.
In Canada, triple pane is likely a more recommended given the temperature extremes. I am not sure that $4,000 is an accurate upgrade fee in most cases.
Old 02-16-2012, 05:28 PM   #4
Rewards Points: 160
replacement windows...and I'm not too sure if I want to spend an extra $4000 for triple panes?
Old 02-16-2012, 05:40 PM   #5
Those prices are extreamly high unless that also includes wraping the window frames with coil stock.
I'd be calling around and getting some more prices.
You do know installing replacement windows is DIY 101, right?
The wraping should only be done by a pro.
Old 02-16-2012, 06:53 PM   #6
Did he mention how many units he had?
Just wondering. Maybe I missed it.
Old 02-17-2012, 09:56 AM   #7
Rewards Points: 160
sorry i forgot to mention, this is to replace all the 30year old windows in my entire house...that is why the prices are so high
Old 02-17-2012, 12:13 PM   #8
MJW
From seeing your other posts, I hope you are going with new construction windows.
How long are you going to be using these windows? How long will they last? Take that figure, and see how much money you may save over that many years in energy costs. Does it add up to more than the difference in price? I doubt it.
How many windows do you have? Must be quite a few windows to add up that high.
MJW is offline   Reply With Quote
Old 02-17-2012, 12:16 PM   #9
MJW
Anyone who says a double pane window will fog up before a triple pane has got A LOT to learn about how a building works.
My guess is that it is condensation they are talking about, not a broken seal.
Old 02-17-2012, 08:41 PM   #10
Rewards Points: 160
Kitchen and bedroom window reg size = 5 windows
1 small bathroom window
1 Big Living Room window
I don't know what goes into a window that makes them so expensive...but I'll shop around a bit more...I thought the prices were high too...although that is an installed price...I think labor is over a grand.
Old 02-17-2012, 09:29 PM   #11
I've got to be miss reading your post 7, windows to $8000.00.
That sounds way to high unless there's some really special windows or a whole lot more labor involved we do not know about.
Old 02-18-2012, 06:11 PM   #12
Rewards Points: 160
$8000 is the installed price, so is the $12000 for the triple pane
Most people around here say that is about right...I will be getting more quotes though
Old 02-18-2012, 06:13 PM   #13
Rewards Points: 528
Where in Canada?
framer52 is offline   Reply With Quote
Old 02-19-2012, 02:22 PM   #14
Pure Genius
Rewards Points: 150
Most windows are priced by united inches. Without seeing your house or the windows its hard to say if that price is high or not. Also you're not really comparing apples to apple using two different manufacturers.
Dierte is offline   Reply With Quote
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
sweating double pane windows etch Windows and Doors 6 10-31-2011 09:30 PM
double and triple up on buses? fabian Electrical 9 01-26-2009 04:17 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
